Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 04-13-2003, 05:29 PM   #1
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Zip Dee maintenance
hey gang,
i was doing my spring check out of my trailer today and noticed my awning was very difficult to deploy.
after spraying silicone into all of the tubes with no improvement, i noticed the awning was hanging up after it had unrolled about 4 inches.
then i figured out that the spring knobs on the stiffener arms were hanging up.
i put a tiny amount of wheel bearing grease in the detent and it worked like a charm!
good as new!
john
Old 04-13-2003, 07:13 PM   #2
Thanks for the tip.
We never had a working awning in our 2 previous AS. Now, our 1990 has awnings all around. We may even use them one day. I'm sure your tip will be useful then.
femuse is offline   Reply With Quote
Old 04-13-2003, 08:16 PM   #3
Chas's Avatar
Images: 22
I had the sorta same problem on mine just on the other arms. One arm did not want to extend. Soaked it down with WD-40 and took a good mallet to it and finally got it to extend. Everyone around me at the KOA probably thought I had lost it, just beating away!! Never knew stainless steel could corrode, finally got it apart and sanded the inner tubes down real smooth and wiped them down with more WD. It was one of those trips, water leak, blown fuse, broken 12v. T.V. connection, (maybe related) water heater hard to lite, fridge pilot blew out!! What the heck, still had a good time!
Chas
Chas is offline   Reply With Quote
Old 04-14-2003, 07:24 AM   #4
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Thats what its all about having a good time
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 04-30-2003, 03:37 PM   #5
Talking
Well, I just had to laugh . . . but I'm glad to know we aren't the only ones beating the awning out in the middle of the campground. Will have to try the grease idea. WD 40 and silicone just haven't done it for the old girl yet. And, I don't want any hernias -- which is just putting the awning out is leading now. I also have pull repair to do. Has anyone found a strong enough thread to use to stitch the awning pull back together? Jules
gimmejul is offline   Reply With Quote
Old 05-01-2003, 04:22 AM   #6
I had a zip dee maintenance day this weekend as well. I got on the zip dee web site and read their recommended maintenance. I took all the tubes apart and cleaned them with soap and water. The tubes had really collected dirt from where I sprayed them last year with WD-40. Zip Dee doesn't advise you to use WD-40 for that reason -it collects dirt. I sanded the poles and put them back together-works great now. Use silicone on all areas that your can't take apart and wipe down.
Lisa
Lisa
Rennegarbe1 is offline   Reply With Quote
Old 12-13-2006, 08:17 AM   #7
More awning maintenance issues.
Yesterday I completed the last task in my routine of testing all the trailer services and doing a shake-down trip before setting out for two months camping. The last task was to extend the awning, clean out any dirt and critturs, put a couple of drops of oil on each end of the tube axles, and re-secure the awning. The awning has worked perfectly for the past 7 years we have owned the trailer. It has been stored under a pole barn for 8 months, out of the rain and sun, but untouched. The rear hold-down securing wheel would not release. I tried WD40, and eventually resorted to a Stilson type wrench. Nothing would move the wheel. I turned it so hard that I sheared the stainless steel pin at the base of the wheel threaded axle. I took the assembly to a workshop, tightened a tooth-faced vice with all my strength on the axle, and used the Stilson wrench on the wheel circumference. It would not budge, and the soft stainless axle just rotated through the teeth of the vice. This was well and truly chemically seized from electrolytic corrosion between the stainless steel axle and the alloy wheel. I have ordered a replacement bracket and wheel from Zip Dee. I decided to pull the awning out to give better access to the bracket. As I did so, the front end of the awning tube fell out of its bracket. The effect and noise was dramatic, but there was fortunately no damage. There is a stainless steel securing setscrew through the central spindle at each end of the awning. This is one and a half inches long, size 10. It should be fitted with a washer and a nylon insert shakeproof nut. The nut and washer had disappeared, and the setscrew had fallen out. I thought I was particular about maintenance, but I'm obviously not particular enough. I have therefore added to my annual maintenance tasks:
1. Grease the threads of the hold-down wheel axles.
2. Check the tightness of the two spindle securing bolts.
I'd like to think that this might help others avoid these problems.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 12-13-2006, 08:23 AM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Thanx for the tips guys. Mine is fairly new, and with these tips, I can prevent future awning problems.
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 12-13-2006, 08:57 AM   #9
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Good day Nick-
Great post! Thank you for sharing your experience with us all. Just a quick question, did you register your ZipDee? I does come with a lifetime warranty on the hardware and you should have received the new parts covered.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-15-2006, 07:57 AM   #10
Rick, good morning. The awning was on the trailer when I bought it seven years ago, and the trailer is nearly 20 years old. I didn't know about any warranty, but perhaps that is only for the original purchaser. The helpful Zip-Dee parts lady made no mention of any warranty. It would certainly be a useful warranty, as there is potential for problems with the main spring, for example.
Nick.
Old 12-15-2006, 09:51 AM   #11
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
During the first trip out of the camping season, I could not deploy the ZipDee by pulling on the fabric loop. It took two of us to pull down on the arms - it seemed like it was locked. After unrolling, the tube fell out (same as above, size #10 screw fell out - glad to have the exploded view diagram with us to determine the needed replacement parts). Took both of us to roll the awning up by hand. called ZipDee when I got home and they surmized the spring was broken, but advised to investigate before ordering a replacement. I removed the spring, and it was essentially a rusted, frozen coil. I dowsed it with WD-40 many times and cleaned the spring inside and out. Reinstalled and works better than ever. Follow the instructions carefully for tensioning the spring.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 12-15-2006, 10:37 AM   #12
CanoeStream's Avatar
St. Cloud , Minnesota
Additional info
We've recently discussed oil-free lubes in this thread; post 10 contains a link to ZipDee's maintenance pages.
5 meter Langford Nahanni
Old 12-15-2006, 10:52 AM   #13
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I've been pretty happy with our Zip Dees. I've heard the company is just a good to customers as Fantastic Vent. I bought some ZipDee awning cleaner for when the time comes, but will keep an eye out for the lube points next season.
Old 12-15-2006, 11:10 AM   #14
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Thanks to all of you for the valuable information! I never even thought of servicing the awnings.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 12-15-2006, 01:22 PM   #15
ScottW's Avatar
Hernando , Mississippi
for gimmejul,
I use dental floss for all my sewing repairs. Works great and is strong.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 12-15-2006, 04:13 PM   #16
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
good tip scott!
minty or regular? just kidding!
john
you call them ferrets, i call them weasels.
Old 12-15-2006, 05:15 PM   #17
john, that's probably not as far off as you think....
i like the cinnamon....
glide floss is made by the gore folks with the same formula for gore-tex....
it seems thick (and expensive) but is both strong and coated with teflon for easy passage....
now how many parents would run a diaper pin across their scalp to help pass the pin thru multiple layers of hippin....
might need a fishin' knot to keep it from pulling back out after yer zipdee repair....
how'm i doin' joe?....
Old 12-15-2006, 05:29 PM   #18
Images: 59
Originally Posted by nickcrowhurst
. . It would not budge, and the soft stainless axle just rotated through the teeth of the vice. This was well and truly chemically seized from electrolytic corrosion between the stainless steel axle and the alloy wheel. .
Nick,
Thanks for the info. Perhaps the problem was a buildup of plaque and tartar between the wheels and axle. Do you floss that area regularly?
Old 10-18-2013, 03:18 PM   #19
Alice&Billis's Avatar
2006 25' Safari
Tyler , Texas
Routine Awning Maintenance
I will admit the routine maintenance to the zip dee was of the deferred variety and only a couple of weeks ago, it finally became necessary to do a bit of that routine variety. I went camping and had a hard time deploying upper and lower arms, operating the upper arm rachets and then two days later...an even more difficult time taking it down. Some claim that WD40 is the answer while others prefer the dry teflon spray. I could not find the teflon spray and after four stores and no teflon I ordered it off of amazon. The day was spent cleaning with WD40 and dressing the arms with the teflon spray. They work better than they did when new and I would describe the action as "slicker than snot." Also checked all the nuts and bolts...found a few that needed a little tightening and one that was about to come apart. I would now recommend regular annual (at least) maintenance to the metal parts of the zip dee awning.
Alice&Billis is offline   Reply With Quote
Old 10-18-2013, 04:54 PM   #20
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
WD 40 can attract dust. I use silicone spray, but not want to try the Teflon.
Zip Dee using Silicone?????? SailAS Awnings 30 09-15-2018 11:12 AM
Replacing Zip Dee awning canvas webspinner Awnings 23 02-06-2012 06:03 PM
Zip Dee Awning Problems lmcatee Awnings 4 01-08-2012 10:33 PM
Zip Dee main arm bars ThreeFingers Awnings 5 09-16-2011 12:11 PM
Zip Dee Ultimat crispyboy Off Topic Forum 2 05-19-2011 12:09 PM
