Old 08-29-2015, 12:30 PM   #1
JConsroe's Avatar
2005 28' International CCD
Salem , Virginia
Zip Dee Issues: upper bracket - stripped screw & plastic strip damage
The upper bracket on my Zip Dee was leaning outward and was creating a gap between the aluminum and the bracket. I took it off, removed the old vulcum, put a new layer of butyl tape on and reinstalled it. It was then I realized the gap was being caused by a stripped screw on the right side. I checked the forums and the only information I can find on this subject is folks adding another layer of metal underneath the bracket or bolting it from inside. I notice there is a dimple where a fourth screw seems like it should go. Should I drill a fourth hole where the dimple is? Use a bigger or longer screw on the stripped screw hole? Someone mentioned jb weld but I want a permanent solution. Any other ideas?
Also i noticed the protective plastic strip is peeling up and is trapping dirt. Whats the proper way to deal with this?
Thanks!!
JConsroe is offline   Reply With Quote
Old 08-29-2015, 12:39 PM   #2
1979 23' Safari
Wayland , New York
I used oversized Olympic rivets.
Old 08-29-2015, 01:41 PM   #3
JConsroe's Avatar
Salem , Virginia
That must be a beast of a rivet!
Im trying to upload some pics but it keeps failing
Old 08-29-2015, 01:52 PM   #4
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Thanks!!
Use the next size stainless steel screw and drill out the 4th hole
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-30-2015, 03:21 PM   #5
1996 25' Excella
Tillsonburg , Ontario
I had the bracket come off my '89. The local dealer confirmed they just use a big pop rivet, which is what I had already done to get it mounted pending a better solution. Oversize screw didn't seem to work without enlarging the hole in the bracket. One of the screws is likely in the rib The other two are just in the skin. Drilling another hole might be necessary as a last resort, just be sure you don't over tighten the new screw.
Cause of my failure was likely the constant gusty winds in the Rio Grande Valley. Got to tie that awning down or roll it up!
JCW
JCWDCW is offline   Reply With Quote
Old 05-05-2016, 08:29 PM   #6
1991 25' Excella
Hartford , Wisconsin
I just had to repair the mounting of the rear top bracket on my Excella. There are 2 screws that should go into the rib and the 3rd screw just hits the skin. Well on mine the skin area had been dented and repaired, right at the vertical skin seam near the bracket mount. Well when they re-riveted the seam, they did a crappy job. Poor riveting of seam, that they gooped up with silicon. When they reinstalled the awning mount they missed the rib, so all 3 scwres were just in the skin. The bracket was loose and had an ugly mess going on. I removed the offending rivets, and goop, and pop riveted the seam with Vulcum. Filed the holes from the crummy bracket mount job, will pop rivets. Placed the bracket on skin and drilled holes for the 3 screws, 2 into rib. Seeing as the rivets I used for filling the screws holes now fell under the bracket, I had to grind reliefs in the back side of bracket to get it to lie right on skin. Used a Dremmel type tool, to grind the reliefs. Then I sealed up the head of the pop rivets and screwed the bracket in place. Fits much better, and now 2 screws have good bite in the rib. Plus the seam fits together much better than before.
TOPORANGER is offline   Reply With Quote
Old 05-05-2016, 08:43 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I used larger screws.
When the old screws pulled out the metal around the screws came outward shape like a cone. I used a punch to carefully flatten the metal back into place which made the stripped holes smaller
A W Warn is online now   Reply With Quote
Old 05-06-2016, 06:05 AM   #8
1996 25' Excella
I used oversized rivets. Local Trailer place with former AS personnel said they also use oversize rivets. Held up fine until I sold the trailer. Our cause was windy conditions in Texas.
JCW
Zip Dee Awning stripped screw holes..... JKnight Awnings 3 08-24-2010 04:16 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee upper bracket fix Zeppelinium Awnings 4 07-05-2007 10:06 AM
Zip Dee Support Bracket LTD93 Awnings 2 12-12-2003 07:51 AM
