Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 11-10-2008, 03:31 PM   #1
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Zip-Dee installation
Well, I've had the hardware for two years, maybe it's time to install the awning! Wouldn't you know it started snowing today...
I'm doing this a little bit backward, in that I only wanted to install the upper clamp as part of the window removal and patch task on my Overlander. The installation instructions provide a measurement only for the bottom main arm hinge (down 71-1/2"), so you have to put the arm together and mount the hinge in order to see where the clamp falls on the shell.
Name:	zip-dee arm-annotated.jpg
ID:	71181Click image for larger version
Name:	IMG_8649-total arm-s.jpg
When you put the arms together, you suddenly realize there isn't any slop in where the clamp mounts to the shell--it's defined by the length of the awning case in the fore/aft direction and by the arms and lower hinge in the vertical. Without getting the case out of the the shipping tube and mounting it on the arms, there is a risk that the clamps could be installed wrong. For example, if one ordered the case based on the length to the skin edges, rather than the rivet lines, it would be a bad day (and I can't remember how I did it--crap). Ou can see by the green line in the drawing above that the clamps are meant to fall right on the rivet line.
I wanted a strong lower hinge attachment, so I began with two doublers. The casting has a step on its face, to provide for the skin lap joint, so you have to do the same with the doublers. The doublers were installed as two one-piece layers, then one was cut right along the skin line and the pieces reassembled in the right layers to provide a tight fit. Eventually the pop rivets will be replaced with bucked rivets, including some flush rivets under the casting.
Name:	IMG_8515 lower hinge parts-s.jpg
ID:	71182Click image for larger version
Name:	IMG_8517 lower hinge assembly-s.jpg
In addition, there will be another doubler inside the shell with nutplates for the screws. This doubler will be installed (actually, it's two doublers, one on either side of the rib flange) when the pop rivets are replaced.
Name:	IMG_8648-bottom bracket-s.jpg
ID:	71184Click image for larger version
Name:	IMG_8647-upper bracket-s.jpg
As soon as I determine the exact case length (that sucker is heavy--not an easy task to move it), I'll know right where to put the upper clamp casting in the fore-aft position. Then I can finally rivet in the window patch with bucked rivets. The window patch is its own doubler, btw, and there will be nutplates on an inside doubler, too. I've seen too many Zip-Dee hinges and clamp castings loose on vintage AS due to deformation of the skin where the screws were installed.
Zep
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Zeppelinium is online now   Reply With Quote
Old 11-10-2008, 04:17 PM   #2
Profile:  1963 26' Overlander
Nice looking work Zep, as per usual. As someone who just recently installed a new patch (exterior doubler in your terminology) where my EZ-Awn upper bracket tore out of the skin, I appreciate your thorough approach.
I'd like to install an interior doubler as you did as well, and especially like the idea of the nut plate, but I'd have to remove the interior endcaps at each end in order to do that.
I suppose that will just have to be a project for another day. Anyway, thanks for sharing!
Old 11-10-2008, 04:44 PM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Zep - When I installed my awning I installed the brackets just as the instructions indicated and everything lined up perfectly. The rivet line was used to determine the location of the bracket as well at the measurement from the rail. The only issue I had was the Vista view frame not allowing the front top bracket from sitting smoothly on the skin. You have previously removed that problem.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 11-10-2008, 06:01 PM   #4
1977 23' Safari
1975 31' Sovereign
Originally Posted by utee94 View Post
...I'd like to install an interior doubler as you did as well, and especially like the idea of the nut plate, but I'd have to remove the interior endcaps at each end in order to do that.
...-Marcus
You don't have to remove the end caps. All three screw holes for the upper clamp fitting can be reached by peeling back the interior skin forward of the door. Peel it back from the end cap end. You have to remove pop rivets for about 3' of length aft along the skin lower edge (and some on the ribs), and you may have to pull the top edge of the door trim loose, but it's not that big a deal.
Oops. just thinking here. Since I took the window out, I also jettisoned the sliding window cover and the plastic surround for that cover. That makes peeling the skin back possible.
Zep
Old 11-10-2008, 08:28 PM   #5
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
I guess my PO didn't like the way those brkt's could move around...so he found someone with a Heliarc and 'glued' them suckers right to the skin! Might be a little more work if one needed to replace those panels...but I'll take the security factor for now!
Name:	Awing bkt [Desktop Resolution].JPG
ID:	71206   Click image for larger version
Name:	Awing brkt 2 [Desktop Resolution].JPG
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated (org...diamonds)
AIR # 11135
1978 - 28 ft Ambassador (Blue Halo)
2001 - Ford Excursion V-10 4x4
Old 11-11-2008, 08:09 AM   #6
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Mexray, I do not want to rain on your parade but you might have a problem down the road with the skin cracking at the edge of the weld. 2024-T3 is not a weldable alloy, I know that it will weld but but there's no strength in the aluminum at the weld line as the heat destroys the tempering. 7075 aluminum also cannot be welded.
Aerowood is online now   Reply With Quote
Old 11-11-2008, 08:29 AM   #7
Zep
My upper brackets are fore and aft of the rivet lines between the endcap and the straight panels. I might be able to unrivet the straight panel, peel back the encap a little bit, and slide a nut plate over to the proper place, but I'm not certain. It will definitely be worth checking out when I am in the position to unrivet and peel back those inner straight panels, which for the aft bracket, should be in the next few weeks. If I can slide in an interior doubler at that point, I will be delighted!
(Actually, since there is already an exterior doubler on each bracket, wouldn't the proposed interior backing plates actually be "triplers?" )
The fore bracket will have to wait until NEXT year when I pull apart the front half of the trailer. For now, the exterior doubler I put on there should hold it well. I used some .050 2024 T3 for that and riveted and vulkemed the heck out of it, and it seems very solid now.
Thanks again for all of your ideas, comments, and suggestions. I really enjoy looking at your work!
Old 11-12-2008, 02:28 PM   #8
Mexray's Avatar
Aerowood....I took those photos the other night...I'd always assumed that those lower support brackets were 'welded' to the skin....
I took another closer look today, and found that the 'bead' is actually some silver colored silicone, and looks just like a good heliarc bead!
Sure fooled me! Looks kinda' cool, though!
Thanks for the note...
Ray
AIR # 11135
Old 08-29-2009, 07:17 AM   #9
1977 23' Safari
1975 31' Sovereign
Zip Dee installation instructions
Lost mine, they were nice enough to send this PDF. It's better than having a paper copy.
Zep
Old 11-04-2009, 08:17 AM   #10
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Zipdee length on 71 Tradewind
I chopped my Roller and Canopy for the second time If I used the whole length of the awning rail the rear bottom bracket end up smack dab in the middle of the battery compartment access door. If I moved 1 rib to the front the bracket ends up in an awkward position on the frame of the compartment. So I moved it up 2 ribs for a length of 12 and a half feet.
Also the front top bracket ends up straddling the vista view window frame to get the correct mounting over the rib, so I had to make a shim. I saw someone else with this delema ground down the base of the bracket.
Incidentally the awning itself was from a ZipDee on a Beaver with Z locks.
I learned to repsect those springs (see my thread Airstream Owies). Most of the rest was from a 75 roll over. which taught me the angles of the arm bends are critical to correct position.
Pay no attention to the man behind the curtain- WoZ
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 09:12 PM
Zip Dee shinola345 Awnings 3 07-19-2006 11:51 AM
Zip Dee Inland RV Center, In The Vendor's Forum 1 07-13-2006 04:31 PM
Zip Dee Awning installation thenewkid64 Awnings 3 04-19-2003 11:08 AM
Zip Dee, Why? Jabba Awnings 7 02-07-2003 06:35 PM
