Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 03-31-2009, 02:59 PM   #1
Profile:  Buena Park , California
Zip Dee Awning Will Not Retract
The awning that came with the airstream we bought has never retracted since we got it. I still use it, but when we need to roll it back I do it all by hand. And now I would like to get to work on repairing it. I am assuming the spring is busted.
How do I go about checking that?
I have read on some of the threads you just need to drill out the four rivets on the spring side, but I am not sure how to tell which side is the spring side. Our awning is on the curbside.
Is the spring on the side closest to front or back?
And should I assume the spring is the problem and just get to opening it up or is there something else I should check first?
Thanks in advance.
kennytheecat is offline   Reply With Quote
Old 03-31-2009, 03:28 PM   #2
Profile:  Corona , California
Thanks in advance.
DON'T TOUCH THE AWNING, PERIOD.
Unless you are familiar with the spring setup, leave the awning alone, as it can severely hurt you.
But, you can call Zip Dee, at 800-3382378, and explain the situation.
They will verbally teach you how to check it out correctly, and/or send you the instructions.
Since you have a computer, they can send the info to you that way as well.
Once you are properly informed, you can solve the roll up issue, post haste.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-31-2009, 05:44 PM   #3
Profile:  1994 30' Excella
Mississauga , Ontario
Andy's right. If the spring is under tension it can take your hand off if you do something in the wrong order.
AL
BigAl is online now   Reply With Quote
Old 04-06-2009, 05:36 PM   #4
The spring was fine. All I had to do was rewind it. I don't know why the PO didnt have it wound. Maybe I will find out! But as of yet the awning works great.
Old 04-06-2009, 06:10 PM   #5
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Isn't it great when something is less of a problem than you originally thought it was going to be?! Whew!
TB & Greg...& Cockers Annie & Sadie
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside Our Bambi: AZBambi Décors
Awning cleaner??? Zip dee... swinginping Awnings 3 06-10-2008 10:42 AM
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Zip Dee Awning Chitown AirStreamers Awnings 11 04-12-2005 08:17 PM
ZIP DEE awning questions jmac Awnings 22 03-03-2005 11:26 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
