Old 08-16-2016, 07:58 AM   #1
1987 32.5' Airstream 325
Windsor , Ontario
Zip Dee Awning Waterproofing
Recent camping adventure saw a fair amount of rain overnight and during the day.
I lean my awning at night if there is a threat of rain for runoff.
Daytime, we were sitting underneath and I was getting a lot of water draining through the fabric.
It's a 1989 so I'm thinking a waterproofing may be in order.
Has anyone done this? What is the product/process used?
Should I expect a certain amount of leakage as if there is too much water pooling the weight may ruin the brackets?
Thanks in advance,
Chris
realpank is offline   Reply With Quote
Old 08-16-2016, 08:02 AM   #2
dznf0g's Avatar
Oswego , Illinois
I have not had to research deeply, as mine doesn't weep yet. There are a variety of fabric waterproofing products out there. I believe Sunbrella makes an approved sealant. Sunbrella material is used on the ZipDees....not sure about others.
-Rich-
Old 08-16-2016, 08:09 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The Zip Dee website has good information on the care and feeding of the awning fabric. Check it out.
Bob Martel
WBCCI# 5766
Old 08-16-2016, 08:16 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
ZD recommends and sells 303 Fabric Guard Water Repellent. The label says "Recommended by Sunbrella". Best price I have found is on Amazon. Pretty good product. I have been using it for years on tents, inflatables and boat awnings. Gave my Airstream awning a good cleaning and treatment about 6 months ago. Seems to be working as advertised.
MICHAEL
Old 08-16-2016, 09:34 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
My experience with 303 waterproofing YMMV....
To completely 'soak' a Zip Dee could get quite expensive.
I now just treat the seams.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-16-2016, 12:02 PM   #6
1978 31' Excella 500
Huntington Beach , California
I've used 303 Fabric Guard Water Repellent, (best price found is Amazon) for years.
Works great for Water Repellent, but better yet for protection from fading. Have a mountain cabin at the 7600' level and "303 Fabric Guard" has been working great at prolonging the Fading from the Sun.
The price of replacing my Airstream Awning, is not something I'm looking at doing soon!
Jerry Ski is offline   Reply With Quote
Old 08-16-2016, 12:14 PM   #7
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
You need to CK with ZipDees on this, we were in Durango the last 3 week rain almost very day with awning out 24/7 and lots of rain, heavy at time and did not have this problem.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 08-16-2016, 12:44 PM   #8
san jose , California
303 has no UV protection
303 has no UV protection, so it will not protect against fading. I checked with 303 jn the past as I have other sunbrella products.
If your awning is not colorful (red or striped blue), it may not be an issue.
vis0rd0wn is offline   Reply With Quote
Old 08-16-2016, 02:01 PM   #9
X2
303 makes no UV claim for Fabric Guard.
303 Aerospace Protectant works very well for UV protection.
RLC
John Prine
Old 08-16-2016, 02:05 PM   #10
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
The 303 High Tech Fabric Guard works very well I used it to re-coat my Sunbrella covered Fleetwood pop up several years ago. It worked very well. No more leaks. I bought a gallon and had nearly half of it left after I was finished. It goes a long way. Depending on the size of your awning you may need much less. As mentioned you can pick it up from Amazon, but several retailers carry it also.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 08-16-2016, 02:39 PM   #11
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
3M water repellent works great too, but full disclosure, never tried it yet on my awing since my is a 2014. I've tried it on other materials, and it does work. You will have to reapply when needed.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 08-16-2016, 03:08 PM   #12
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
I am not at all surprised that your trailer's awnings would need re-waterproofing. We've had several AS in that age range and they all needed it. As stated by others, follow Zip Dee's online cleaning instructions (including the bleach solution) and follow after thorough drying with the 303 fabric guard, water repellent product. It absolutely works and will return the Sunbrella fabric to its original water-shedding performance. It is not cheap. Neither are new awning fabrics. Unless you scrub it often with strong detergents, it will last several years under normal usage. Not so long if you full-time and leave the awnings out a lot. I have not worried about the UV products, because we aren't full-timers yet. (But we plan to be soon) It will "hold" water better after you do it. You'll still need to tilt it if you leave it up during rain chances.
Good luck to you.
fwjumper is offline   Reply With Quote
Old 08-16-2016, 10:33 PM   #13
Windsor , Ontario
Waterproofing
Tremendous response friends !
Thank-you so much
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip-Dee Awning Repairs ViewRVs Awnings 3 08-31-2006 06:28 PM
Zip Dee awning problem DbackFan Awnings 12 04-06-2003 01:47 PM
