Old 08-23-2010, 09:01 PM   #1
1971 31' Sovereign
Greenville , Texas
Zip Dee Awning stripped screw holes.....
I have a 71 Sovereign with a Zip Dee Awning. The rear lower brace is only being held on by one screw. I have attempted to replace the two stripped out screws with larger ones and they too have stripped out. Any ides on how to secure these?
Thanks.
JKnight is offline   Reply With Quote
Old 08-23-2010, 10:01 PM   #2
Thanks.
Those brackets are supposed to be riveted in, with 3/16 inch rivets.
Old 08-24-2010, 03:38 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Our bracket was also held in place by 2 #12 stainless screws on the rib and a rivet on the skin. The rivet was pulled loose at one time. Not the ideal solution but I replaced the rivet with one of these and drew it down with the screw that came with it. Then backed the screw out and replaced it with a stainless screw and washer. It tamped down tight and has held well.
expansion bolt: Definition from Answers.com
Old 08-24-2010, 04:16 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Rivet a plate to the skin and then rivet the hinge to the plate.
Zip Dee Awning Chitown AirStreamers Awnings 14 06-09-2011 03:11 PM
Used Zip Dee Awning Price CrzyCorpsman Awnings 12 02-25-2010 09:55 PM
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
ZIP DEE awning questions jmac Awnings 22 03-03-2005 11:26 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
