I am a big proponent of Rivnuts. You might call Zip Dee too. They are very helpful.
__________________ "If it can't be reduced, reused, repaired, rebuilt, refurbished, refinished, resold, recycled or composted then it should be restricted, redesigned or removed from production."
Because of my own carelessness,leaving my zipdee deployed,during a popup thunderstorm. In which the rafter arms were ripped off and throw 10 feet over and beyond the trailer. Fortunately,although being a small guy I was able to corral the zipdee and get it rolled up.
Unfortunately the force of that trip over the trailer pulled all the rivets. I went back with larger stainless steel screws and plenty of caulk on the threads and under each bracket and fitting.I also had to drill each hole in the brackets to except the larger screws.
They dont show and I have had no leaks as of yet.
\Good LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
