Old 02-17-2015, 04:39 PM   #1
gnmostream's Avatar
1970 21' Globetrotter
Pagosa Springs , Colorado
Images: 8
Question Zip Dee Awning Retrofit to 69 Globetrotter
After extensive research and searching for parts I have all the proper parts to retrofit a Zip Dee window awning to my 69 Globetrotter. Has anyone cut down a roller tube to shorten it? If so how do you calculate the length of the roller tube between the ribs so it will be the correct length for the arms???
Example: My rear window rib from left to right is 44 & 7/8" on center of rivets. My curbside length is 93 & 1/4" from center of rivets.
Any help is greatly appreciated.
gnmostream is offline   Reply With Quote
Old 02-17-2015, 07:58 PM   #2
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Call zip dee And ask them what size awning you need for your year & calculate from there. Not sure they would tell you how to cut the tube, but if you inquire about buying awnings, they will tell you what size you need.
Cochese is online now   Reply With Quote
Old 02-17-2015, 08:53 PM   #3
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
Suggest you PM Smartstream - he's cut down tubes/awnings for his MOHO I believe...
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
OilnH2o is offline   Reply With Quote
Zip Dee Electric Awning Retrofit jschellent Awnings 7 03-18-2014 07:34 AM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee retrofit 59er Awnings 5 07-18-2007 02:05 PM
