Old 07-08-2009, 07:22 PM   #1
Davis's Avatar
1996 34' Excella
Americus , Georgia
Zip Dee awning pull strap broke ?
My Zip Dee patio awning pull strap broke or the thread holding it together gave away. Do you have any suggestions on how to repair this without removing the awning ? Thanks Davis
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 07-08-2009, 07:44 PM   #2
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
We just opened the awning fully, and then I doubled over the end of the strap to give it a little more body and then just riveted it directly to the awning roller.
Annette
bullydogsmom is offline   Reply With Quote
Old 07-08-2009, 07:49 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Davis,
Not sure but doesn't the strap fit in a slot on the rail? If that is the case it is fairly easy to purchase a replacement strap and slip it in. I know that is the case on the other brands. I have a Zip Dee on one trailer but have never messed with it.
Aaron
WBCCI #XXXX AIR #2495
Old 07-08-2009, 08:43 PM   #4
Call Zip Dee at 800-338 BEST
Ask for Linda or Jim.
Old 07-08-2009, 09:01 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Be a sail maker
As I understand it....your talking about the strap on the outer edge of the awning....opposite side from the rail or roller. I think you could extend the awning, take the detached strap and fold it over a couple inches for
reinforcement thickness. Then hand sew, lash, it to the outer edge of the awning material. Use good thread. Or, you could poke three or four small holes thru the folded strap and awning edge and use small rivets with washers on either side of the material for reinforcement thru those holes. You can use small machine screws with nylon lock nuts instead of rivets too.
Old 07-09-2009, 04:20 AM   #6
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks for the replies. Andy I will check with the people you suggest also.
AIR # 5131
Old 07-09-2009, 06:06 AM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I just replaced my pull strap a couple of weeks ago. I got the new strap from Vintage Trailers (I think). You just have to drill out 3 rivets, place the new strap over the old rivet holes, & install 3 new rivets to hold it in place. Took me about 5 minutes. The new strap was about $28 or something like that.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-09-2009, 08:02 PM   #8
Davis's Avatar
1996 34' Excella
Americus , Georgia
Hi Andy,
I contacted Linda today and ordered a new pull strap that comes with rivets and instructions. Thanks Davis
AIR # 5131
Old 07-09-2009, 08:54 PM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I talked to Zipdee and they said just rivet a new strap on to the roller. I am going to use some nylon climbing webbing, just because I have it.
Lumatic is online now   Reply With Quote
Old 08-02-2009, 10:02 AM   #10
1979 30' Argosy
Sunriver , Oregon
Andy, You appear to be the Guru on Airstream's. I'm a New be and need all the advise I can get. My awning is stuck open, any suggestions? Thanks, Korina
kchinchen is offline   Reply With Quote
Old 08-02-2009, 11:34 AM   #11
richinny's Avatar
2011 34' Classic
there is a small lever at the front of the long roller. it tilts out a little bit to let the roller wind back up. has that been done?
Awnings By ZipDee
Ricky
Old 12-26-2009, 04:25 PM   #12
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
I repaired mine ,like new with awning thread and a heavy needle.better than new.
wbcci ,#3510 NEU & 4cu http://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 12-26-2009, 04:35 PM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
Not to usurp the guru, but will the awning roller rotate if you try and turn it by hand, or is it frozen up? What I'm getting at is your return spring broken or stuck? You don't have Z locks (little levers) on the ends of the roller tube do you? I assume you have a Zipdee awning right?
Old 12-26-2009, 04:57 PM   #14
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
A old timer AS couple told us how to repair awnings; use dental floss instead of thread.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Zip Dee Awning Chitown AirStreamers Awnings 14 06-09-2011 03:11 PM
Zip Dee Awning Will Not Retract kennytheecat Awnings 4 04-06-2009 06:10 PM
Awning cleaner??? Zip dee... swinginping Awnings 3 06-10-2008 10:42 AM
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
