Old 06-19-2016, 12:59 PM   #1
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Zip Dee Awning... Protocol avoiding Disaster
These points are among some everyone needs to be aware. This includes the WBCCI and Boondocker trailer owners of any brand. Part of this post was among another Thread, but I should have saved myself some criticism and started a Thread on my own. If YOU find this offensive... good. You might have saved your awning if you consider each point.
Common Sense is not common, nor gifted to everyone. For 'Boondockers', substitute any term you like that fits your use and maintenance of your trailer.
Boondockers understand that having an extended awning comes with caveats.
-Wind. The awning is not designed to handle gusts nor steady winds. Adjust for the conditions. Your support rods can bend and be damaged.
-Rain. You need common Boondocking understanding to have your door entry awning set higher than the opposite end. This way the water does not pool, but runs off and away from your doorway. Pooling water on your awning WILL be fatal...
-Snow. Do not even have your awning extended as it will fail.
-Sunshine. When NOT in your trailer, lower your awning to the lowest setting to avoid all of the above.
-Evenings. It is best to roll your awning up. Unless you can predict the above conditions with a magic ball, it is 100% effective. If it is raining and you are in a sheltered area, secure the ends with some weight. Some disagree with that option, but that is their choice. Not mine.
-Experience. It is best that you and I learn from the misfortunes of others. This is a continuing learning experience. It is not by accident that the longer you own a trailer with an awning... you just might be able to help those in need of advice. It may not be well taken... but neither is forgetting to secure your hitch to the tow vehicle properly on that foggy drizzly morning vacation!
It is disappointing that you learned the hard way, but not the first. Be prepared to use common sense in the use of your awning. No Airstream Owner's manual will discuss these caveats for your awning's use and under what conditions.
I am sure you will be more careful in the future. It was not the failure of the awning, but your failure to apply common sense under possible conditions of use. This is intended to 'educate' those following your disaster, so others can learn.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 11-21-2016, 02:46 PM   #2
1988 34' Excella
Stanardsville , Virginia
Thanks Ray, I wish this info was in my manual before I tried to out guess the weather report and leave my awning deployed over night! I tend to learn things the hard way by trial and error.
madpiper is offline   Reply With Quote
Old 11-21-2016, 03:08 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
My daughter & I are OCD about our Zip Dee awnings. Our relatives have SOB ones & don't seem to care as much about theirs. Guess whose bent in half when it wasn't tilted in the rain......think they'll be OCD about theirs now, since it'll be new!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-21-2016, 03:19 PM   #4
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
No damage but almost. High wind developed after midnight as we enjoyed pleasant dreams.......fortunately my wife, a light sleeper woke me to retract the awning just before the gusts reached over 35mph & took out our neighbors awning. A lesson well learned!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 11-21-2016, 03:53 PM   #5
Holly Springs , Mississippi
Boy, am I glad I read Ray's posts. I won't live long enough to make all the mistakes myself. Very nicely written head's up.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 11-21-2016, 04:57 PM   #6
2012 19' International
Southeastern MI , Michigan
If you don't weave the strap back and forth while rolling it up it will not close properly
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 11-21-2016, 08:26 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Careful not to weave it back and forth too much or it will shorten the strap too much and it can get sucked inside the roll. Voice of experience.
MICHAEL
Old 11-21-2016, 08:48 PM   #8
interstateflyer's Avatar
2017 25' International
Los Osos , California
I always zip-tie my awning arms when rolling.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 11-22-2016, 10:52 AM   #9
Newbie
vossom's Avatar
2016 28' Flying Cloud
Central , New Jersey
Thanks for sharing these tips! I am guilty of not tilting when it was raining, but never again!
vossom is offline   Reply With Quote
Old 11-22-2016, 12:38 PM   #10
I use the rod to retract it. I'm too short to hold the strap all the way in.
The rod to tighten the two wheels is also a bad idea. I use a little step stool and do it by hand.
Hensley Arrow hitch
Old 11-22-2016, 07:15 PM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
We have a short window shade awning about 20 feet in length on the street side of our Limited. It does not have any lock downs while traveling.
I was caught in vicious crosswinds on eastern Colorado I-76 and the street side awning unrolled on me. It billowed up like a jib sale. I thought it might drag the trailer over on its side, or simple rip out the awning anchors. I rigged a hold down out of some rope and traveled on slowly. The gusts were over 50 mph. I had a hard time standing up in that damn wind. The semi trailers were really listing and fighting to steer straight.
It is a 30 year old Airstream. Maybe the retract springs are getting weak. But now I tie that awning down when traveling.
David
Old 11-23-2016, 06:02 AM   #12
AWCHIEF's Avatar
Images: 33
Ditto,I find it easier and have better control to use a small 3 step ladder to safely open/close the awning and manipulate the awning locks.
MICHAEL
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
need polishing protocol goshawks00 Cleaning, Stripping & Polishing 13 12-06-2012 05:31 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Battery Charging Protocol - Motor Homes winner Airstream Motorhome Forums 6 05-20-2003 09:51 AM
