Old 01-04-2012, 04:30 PM   #1
Zip Dee Awning Problems
AS has been on the Oregon Coast for 8 years. Most is OK except the Zip Dee awnings will no longer roll out or in. Hardly ever used, not that hot in Oregon. Since the problem seems to be on every awning; I am guessing the salt spray mist has clogged up the spring mechanisms. I have a single page repair sheet from Zip Dee but has anyone actually taken these apart. I can see 100' spring flying all over my garage.
thanks..
lmcatee is offline   Reply With Quote
Old 01-04-2012, 04:52 PM   #2
1976 31' Sovereign
Scranton , Arkansas
DID a spring change out 15 yr ago. Simular to a garage door. Must drill rivets out. Best of memory you wind up spring to specs in instructions. Be careful can eat your fingers. Had a frozen awning on current 76 purchased last year. Sprayed pentrating oil in both ends. Let set for a few days. Use 2 step ladders and 2 people. Pull out from the top. May get lucky as I did. Frenchy in Arkansas
L.C. is offline   Reply With Quote
Old 01-04-2012, 05:52 PM   #3
thanks..
DON'T TOUCH ANYTHING, until you talk to Linda at Zip Dee.
800-3382378
Old 01-04-2012, 06:15 PM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Agree with Andy; our coach has lived in salt air most of it's life and, other than some lube to the awning ends, we've done nothing except to be very carefull when opening and closing the awnings. The small awnings will open in high winds and rack, which I think might have happened. Hold-downs should have been factory.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 01-08-2012, 10:33 PM   #5
I drilled out one rivet on each end of each awning and squirted some de-greaser & WD-40 inside. Rolled a little and rolled some more, let it set, worked on the next awning and by the end of the day; all 5 were working.
Thanks for you input on this...
awning, zip dee
Zip Dee awning for '61 Tradewind 61 Streamy Awnings 10 03-27-2013 08:49 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee main arm bars ThreeFingers Awnings 5 09-16-2011 12:11 PM
Zip Dee Awning Repair - Golf Cart Accident jbbaldwin Awnings 0 08-15-2011 01:16 PM
Zip Dee using Silicone?????? SailAS Awnings 19 06-12-2011 12:39 PM
