Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 10-11-2009, 07:30 PM   #1
Profile:  1984 31' Excella
Bel Air , Maryland
Zip Dee Awning now works as it should
I picked up a used 84 excella a few years back and have had a horrible time setting the awning (two person job). After reading some postings on this forum, I called Zip Dee and they gave me great customer service and instructions. this weekend I cleaned and straightened my arms and now the awning opens easily with one person. What a pleasure.
Thanks to all.
Silverscream is offline   Reply With Quote
Old 10-11-2009, 08:30 PM   #2
Profile:
Not to Zippy
Silverscream
I feel your pain every time I try to put up the Zip Dee Awning on my 1987 Sovereign. Mine is a two person job, plus a boy!! Just out of curiosity what modifications did you make?
dano is offline   Reply With Quote
Old 10-15-2009, 06:06 PM   #3
Bel Air , Maryland
This is what they told me.
1. take an arm off the airstream by unbolting the bottom bracket and unbolt from the awning. (I had 1/2 bolts/nuts)
2. remove the male arm from the female arm.
3. with a green scrubby, clean the male arm of residue.
4. with hot water, clean the inside of the female arm (I just poured hot water down the tube). Dry (I used compressed air)
5. Make sure the male arm is straight. You can use the trailer ball/hitch to bend the arm back to straight. This took a while. It should be straight. Try it carefully in the female tube and see where it binds. It took a few trys to bend it straight since it was bowed abit.
6. Clean the male arm with alcohol.
7. Spray with silicone. Don't use WD 40.
8. reassemble and put on trailer.
9. Repeat with other arm.
I would recommend talking to Zip Dee, the person on the phone was nice and helpful. I wish you the best, it really worked for me. It is now an easy one man job. Let me know if you need anything else.
Two Adults, Four Kids, and a Dog camping in an Airstream. We must be crazy!
Old 10-15-2009, 08:33 PM   #4
Spokane , Washington
I found some interesting how to videos posted on YouTube. Go to their site and search for Zip Dee and you should find them. One shows how to straighten the arms.
aftermath is offline   Reply With Quote
Old 10-16-2009, 11:17 AM   #5
76sovereign's Avatar
Profile:  1976 31' Sovereign
ozark , Missouri
Thank u
Great advise....Our AS awning is a 2 man job also....
http://airstreamremodel.blogspot.com
http://vimeo.com/kani
76' 31' Sovereign
76sovereign is offline   Reply With Quote
Zip Dee Awning Will Not Retract kennytheecat Awnings 4 04-06-2009 06:10 PM
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Zip Dee Awning Chitown AirStreamers Awnings 11 04-12-2005 08:17 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
Zip Dee awning problem DbackFan Awnings 12 04-06-2003 01:47 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
