Old 09-20-2014, 09:31 AM   #1
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Zip Dee awning lift handles - well worth it!
I had a chance to use my handles for the first time a couple weeks ago, and they're a big help. If you're on the fence about them, like I was due to the price, go ahead and bite the bullet.
Old 09-20-2014, 09:37 AM   #2
dznf0g's Avatar
Oswego , Illinois
I bought a pair a few years ago, and was not as enamored as you. Although they, in theory are a big help, mine began slipping on the awning arm after awhile. Especially after cleaning and a silicone spay application. They just don't bite well on the awning arm. Took them off and just lift by the roll tube.
-Rich-
Old 09-20-2014, 09:59 AM   #3
drboyd's Avatar
1978 25' Tradewind
I guess it might be the case then that your choices are (a) fastidious maintenance or (b) lift handles. My trailer sits out in 115 heat all summer, which cooks the silicone out pretty quick.
Old 09-20-2014, 10:14 AM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I installed the handles before our last trip and since I am 5'6" I like them a lot.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-20-2014, 10:18 AM   #5
dznf0g's Avatar
Oswego , Illinois
It could be that the "biting edge" needs occasional "sharpening" too. I just decided they weren't worth the hassle. I'm 5'10" and can reach the roll all the way to the top notch on tip toes. If the site slopes off a lot, I use the step stool, which I use to get a good pull on the horizontal arms anyway.
-Rich-
Old 09-20-2014, 10:19 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Maybe I just am not using them right, but they seem more trouble than they are worth to me.
MICHAEL
Old 09-20-2014, 10:28 AM   #7
dznf0g's Avatar
Oswego , Illinois
You have to be sure that you keep quite a bit of torque on the handle while lifting.
-Rich-
Old 09-20-2014, 10:29 AM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I put a set on a few years ago when we first got the trailer because I was having some difficulty putting the awning up.
I liked them a lot at first and found they did indeed make things easier, but more recently, I find it just as easy - maybe easier - to just push up on the awning roller.
If there is an advantage to the handles, I suppose maybe it is that when you get the awning higher, you can move the handles to a new position further down the awning arm to make it more convenient.
Mine are still installed - sometimes i use them, sometimes not!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-20-2014, 12:49 PM   #9
1976 31' Sovereign
Oswego , Illinois
At 80 yrs. old not as strong younger. I use lift handles then lower on arm then take another lift easy for me, also I have destroyed right rotator cuff and torn right bicep both non repairable, for me they are great. lifting on tube not an option. Before had carefree awning had lift handles on arms with out them could not raise arms. I tried to lift arms when at zip-dee fact. very hard put handles on with awning install well worth little extra money, Alo I found on amazon a resin 2 step stool that folds flat or open by a handle use to turn hold down knobs get much tighter than with hook, use hook turn small hook then to open awning. I learned about stool trick from airtandem [thanks Mike]
Old 09-20-2014, 01:43 PM   #10
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Short (5'6"), Stumpy (no way am I going to put that in print), and grateful to have a pair.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 09-20-2014, 01:59 PM   #11
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Yeah I am 6 feet tall and sometimes it's hard to reach up and push the roller to get to 4th notch - but I manage
I can see how these would be nice - it makes no sense but I cannot bring myself to buy them - oh don't worry - I find other ways to blow much more money on the trailer
PharmGeek is offline   Reply With Quote
Old 09-20-2014, 02:05 PM   #12
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Hmmm, you learn something new every day. I'd never heard of these things so had to go Googling. I've never felt the need of help with the awing but I suppose the handles would be quite useful.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 09-20-2014, 02:07 PM   #13
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I am 6 feet - at times i simply cannot push the awning rail high enough without a step stool - in those cases I grab lower on the awning rail and push up - it's a bit clunky to do
Wondering if some AS's awnings are not as tall as talk as others ?
Old 09-20-2014, 02:08 PM   #14
dznf0g's Avatar
Oswego , Illinois
In all fairness, I know there will be the day (God willing I live long enough) that I'll re-install them and need them.
-Rich-
Zip Dee Lift handles Zia Airstream Classifieds 0 04-22-2014 08:21 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
What is a ZIP DEE AWNING 27' worth? WILDRTEXAS Awnings 21 09-25-2010 01:35 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
