Old 09-22-2014, 07:20 PM   #43
richinny's Avatar
2011 34' Classic
i've put a small cushion between the middle support rod and the awning. i need to put velcro on the rod so it doesn't fall out when the wind lifts the awning.
Ricky
Old 09-22-2014, 07:22 PM   #44
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Fantastic simple idea - I'll try that!
The atoms of our bodies are traceable to stars that manufactured them...We are not figuratively, but literally stardust.
PharmGeek is offline   Reply With Quote
Old 11-06-2014, 07:26 AM   #45
Natty Lite's Avatar
Mandeville , Alabama
Never knew that this handles even existed? Great idea! I'm going to make my own!!!
Natty Lite is offline   Reply With Quote
Old 04-18-2016, 08:08 AM   #46
2015 23' Flying Cloud
Livermore , California
After reading through this is sounds like the consensus is that the handles are not needed?
cactusjk is offline   Reply With Quote
Old 04-18-2016, 08:24 AM   #47
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
We find the handles helpful in getting the awning to and from the fourth notch, so to us, they are worth it. Joe
jayseejay is offline   Reply With Quote
Old 04-19-2016, 08:10 PM   #48
So now we are torn. Sounds like they are good to have but not essential. Do they damage/mark the supports with the way they clamp on?
Old 04-19-2016, 09:17 PM   #49
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I removed mine and there is no indication they were ever installed. So no damage and no marks.
MICHAEL
Old 04-19-2016, 09:18 PM   #50
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
I saw the handles on another trailer at a rally and thought they would be a good idea until I checked into the price. I decided to make my own. I got on ebay and bought a 1" square solid aluminum bar and cut it at an angle and then bent a section of 1/8" X 1" aluminum strap to make the mounting strap. I measured about 10 times before deciding where to drill the mounting holes for the strap and bar. I mounted them on the lift arms and eureka, they worked and only cost about $8. I use a piece of velcro strap to hold them in place against the lift arm when not in use. It does make the lifting of the awning much easier, especially adjusting after it is up.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 04-20-2016, 07:37 AM   #51
Good to know. Thanks
Zip Dee Lift handles Zia Airstream Classifieds 0 04-22-2014 08:21 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
What is a ZIP DEE AWNING 27' worth? WILDRTEXAS Awnings 21 09-25-2010 01:35 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
