09-20-2014, 09:31 AM
1978 25' Tradewind
Metro Phoenix
Zip Dee awning lift handles - well worth it!
I had a chance to use my handles for the first time a couple weeks ago, and they're a big help. If you're on the fence about them, like I was due to the price, go ahead and bite the bullet.
09-20-2014, 09:37 AM
Oswego
I bought a pair a few years ago, and was not as enamored as you. Although they, in theory are a big help, mine began slipping on the awning arm after awhile. Especially after cleaning and a silicone spay application. They just don't bite well on the awning arm. Took them off and just lift by the roll tube.
-Rich-
09-20-2014, 09:59 AM
1978 25' Tradewind
Metro Phoenix
I guess it might be the case then that your choices are (a) fastidious maintenance or (b) lift handles. My trailer sits out in 115 heat all summer, which cooks the silicone out pretty quick.
09-20-2014, 10:14 AM
2012 25' FB International
Trent Woods
, North Carolina
I installed the handles before our last trip and since I am 5'6" I like them a lot.
Larry
09-20-2014, 10:18 AM
Oswego
It could be that the "biting edge" needs occasional "sharpening" too. I just decided they weren't worth the hassle. I'm 5'10" and can reach the roll all the way to the top notch on tip toes. If the site slopes off a lot, I use the step stool, which I use to get a good pull on the horizontal arms anyway.
-Rich-
09-20-2014, 10:19 AM
Biloxi
, Mississippi
Maybe I just am not using them right, but they seem more trouble than they are worth to me.
MICHAEL
09-20-2014, 10:28 AM
Oswego
You have to be sure that you keep quite a bit of torque on the handle while lifting.
-Rich-
09-20-2014, 10:29 AM
2005 30' Classic
Burlington
, Ontario
I put a set on a few years ago when we first got the trailer because I was having some difficulty putting the awning up.
I liked them a lot at first and found they did indeed make things easier, but more recently, I find it just as easy - maybe easier - to just push up on the awning roller.
If there is an advantage to the handles, I suppose maybe it is that when you get the awning higher, you can move the handles to a new position further down the awning arm to make it more convenient.
Mine are still installed - sometimes i use them, sometimes not!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
09-20-2014, 12:49 PM
1976 31' Sovereign
Oswego
At 80 yrs. old not as strong younger. I use lift handles then lower on arm then take another lift easy for me, also I have destroyed right rotator cuff and torn right bicep both non repairable, for me they are great. lifting on tube not an option. Before had carefree awning had lift handles on arms with out them could not raise arms. I tried to lift arms when at zip-dee fact. very hard put handles on with awning install well worth little extra money, Alo I found on amazon a resin 2 step stool that folds flat or open by a handle use to turn hold down knobs get much tighter than with hook, use hook turn small hook then to open awning. I learned about stool trick from airtandem [thanks Mike]
09-20-2014, 01:43 PM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
Short (5'6"), Stumpy (no way am I going to put that in print), and grateful to have a pair.
09-20-2014, 01:59 PM
2014 30' FB FC Bunk
Hoover
, Alabama
Yeah I am 6 feet tall and sometimes it's hard to reach up and push the roller to get to 4th notch - but I manage
I can see how these would be nice - it makes no sense but I cannot bring myself to buy them - oh don't worry - I find other ways to blow much more money on the trailer
09-20-2014, 02:05 PM
2011 28' International
Chatham
, Ontario
Hmmm, you learn something new every day. I'd never heard of these things so had to go Googling. I've never felt the need of help with the awing but I suppose the handles would be quite useful.
09-20-2014, 02:07 PM
2014 30' FB FC Bunk
Hoover
, Alabama
I am 6 feet - at times i simply cannot push the awning rail high enough without a step stool - in those cases I grab lower on the awning rail and push up - it's a bit clunky to do
Wondering if some AS's awnings are not as tall as talk as others ?
09-20-2014, 02:08 PM
Oswego
In all fairness, I know there will be the day (God willing I live long enough) that I'll re-install them and need them.
-Rich-
09-20-2014, 02:25 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
We have them too. I use them about half the time. Other times I just grab the arm and pull it out.
Bob Martel
WBCCI# 5766
09-20-2014, 02:46 PM
1976 31' Sovereign
Oswego
I will get a lot of flack about this but people spend much money to buy AS & tow vehicle plus many other things for AS but cry handles to expensive when zip-dee awnings are in $3500 to over $4000 range.
09-20-2014, 02:50 PM
Chelsea
, Michigan
You'll get no flak from me featherbedder, I hear you!
Bob Martel
WBCCI# 5766
09-20-2014, 02:51 PM
2014 30' FB FC Bunk
Hoover
, Alabama
Insert flack here!
09-20-2014, 02:55 PM
Chelsea
, Michigan
Originally Posted by PharmGeek
Insert flack here!
Hah, hah!
Bob Martel
WBCCI# 5766
09-20-2014, 02:57 PM
2022 Atlas
Homosassa
I have them and use them each trip. The 4th notch on the front would be a challenge without the handles at least for me anyway. I too use a small step stool for the round knobs.
