Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 04-18-2003, 06:05 PM   #1
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Zip Dee Awning installation
I just picked up 3 new Zip Dee awnings for my Roadside windows. All of the parts are there, awning rail, arms, brackets, rivets, warranty card, and hook. But no installation instructions. Before I start drilling holes I really want to read the instructions, honestly......
Does anyone have a copy I can get via email or fax??
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 04-18-2003, 08:36 PM   #2
Tikihut
Tikihut's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
schaumburg , confusion
Call zip dee at 1-800-338-2378 or visit there web site www.zipdeeinc.com . they can give you all the info you need.
Chris
I will be buying one for my Argosy next week they are located 10 miles from me.
Tikihut is offline   Reply With Quote
Old 04-19-2003, 09:54 AM   #3
dtbw
dtbw's Avatar
Profile:  1999 34' Limited
2002 19' Bambi
Allen , Texas
MIssing Instructions?
I purchased a rear awning and a second full sized awing for the roadside of our Bambi directly from Zip Dee and both came with VERY well written installation instructions and ALL the piece parts including rivets. If you bought directly from Zip Dee, there must have been an oversight. The installation of your side awnings will be very similar to the installation of my rear awning. One thing you will need to buy and have on hand BEFORE drilling your first hole is a tube of Vulken 116. I was warned by my Airstream service center to NOT use silcone sealer as it can attract and hold water behind it and cause the aluminum to oxidize where as the Vulkem will NOT attract water. I got mine at our local Airstream Service Center (N Dallas RV). After drilling your holes, you fill each one with some of the Vulken, then apply a nice amount to what ever you are about to rivet in place (such as the awning rail), then you install the rivets. As all the rivets used are the pop type, there is a chance of leakage where the pull nail breaks off the rivet during installation, so I applied a dap of the Vulken to totally cover the rivets. It takes several days for the Vulken to cure to touch (it never really hardens), so I placed a small patch of plastic wrap to the covered rivet heads so as to prevent the Vulken from getting on the awning when in the retracted position. Once a week or so has passed, you can remove the plastic wrap. Another thing to know is the Vulken 116 can really be a MESS to work with. It is extremely sticky. I found that I could easily clean up with denatured alcohol (Home Depot).
david
dtbw is offline   Reply With Quote
Old 04-19-2003, 10:08 AM   #4
thenewkid64
Just a member
Images: 21
david,
Thanks for the info. I purchased these from an RV boneyard, but they must have gotten them from a defunct dealer.
I will use Olympic rivets to attach the awning rail so I should not have to worry about the sealing of the holes, but I like your saran wrap idea
Brett G
New Awning Zip Dee or Carefree..??? Happycampers Awnings 18 03-09-2004 05:13 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
Zip Dee awning problem DbackFan Awnings 12 04-06-2003 01:47 PM
