Old 06-13-2012, 04:24 PM   #15
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
GT: When I saw your original post just now, I was gonna say that unless your awning is different than ours (which I doubt), there are 4 holes... but you figured that out on your own. We always use the awning all the way up (4th hole) unless there is a little rain, then we lower the rear arm to 3 holes to create a run-off angle to the rear so water doesn't pool. (This is especially important with longer awnings.)
TB & Greg and Abbey Schnauzer
#3954
TBRich is online now   Reply With Quote
Old 06-13-2012, 04:40 PM   #16
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Ha live an learn I guess and I am sure learning these days living in the AS full time LOL
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 06-13-2012, 04:41 PM   #17
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
The first time we extended our awning I got extremely frustrated and just walked away. When I came back my wife had it extended and everything looked good. She has much more patience than me.
The arm/extention is as awkward as anything I've ever seen. Be careful of getting the web between your thumb and fingers pinched. Thats where it bit me. I suppose with practice and patience it will become an easy task. However, It should be easier than it is. The silicone lube spray burned like crazy when I pinched my hand.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 06-13-2012, 04:51 PM   #18
Naper's Avatar
Loretto , Ontario
If there is anything I don't like about our Airstream I would have to say its the Zip De
Naper is offline   Reply With Quote
Old 06-13-2012, 04:58 PM   #19
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We had the same problems with extending the awning and it took my wife looking at the video several times to figure it out. The written instructions are not easy to understand.
I noticed the Airstream store has some handles for too much money that may make it easier to pull out the awning to avoid rubbing the door.
We don't use it much, so we forget how to open it by the time we use it. Nice awning, hard to open unless you do it a lot. The awning material probably needs to be stretched periodically to work better.
Gene
Old 06-13-2012, 05:13 PM   #20
dznf0g's Avatar
Oswego , Illinois
I was going to say mine has 4 holes, but I was afraid yours would be different and you'd pull the rod out of the tube and everything would crash down and tear up a whole panel. I figgered it would be safer to tell you to take it apart and then discover the 4th hole! All is good, don't kick yourself. Take the wheel of, fill the holes with a couple of olymp[ic rivets and it'll be a mystery forever to come, except to you.
-Rich-
Old 06-13-2012, 05:32 PM   #21
funkill's Avatar
reno , NV
Images: 27
Gene
I bought the handles and although it does help me extend the awning to it's highest position. it's still tough. Maybe it's due to my rather limited arm strength??? I still end up pulling up a picnic table, ladder, large cooler, etc so that I can stand on it and push up-n-out on the roller to extend the awning to it's highest position.
Laura
funkill is offline   Reply With Quote
Old 06-13-2012, 05:46 PM   #22
danlehosky's Avatar
Laura, I don't think it's hand or arm strength. It's just in an awkward position. If you get the angle right, it will slide. My wife did it when I couldn't make it budge. Gene, you're right about the use factor. The same thing happens to me when I have to change my car clock from daylight savings time to regular time. It's become easier with the new vehicles though. If for no other reason than the brutal pinch points Zip Dee should change this set up. How long has the current extention design been in use?
If people avoid using a product because it's difficult to operate, it needs to be looked at by the manufacturer. I won't extend mine again without some gloves, or better yet I'll just refuse to do it and eventually my wife will do it herself.
Dan
TAC
Hope is not a plan.
Old 06-13-2012, 05:57 PM   #23
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Finger savers....arm strength enhancers.
ID:	160935   Click image for larger version
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-13-2012, 06:24 PM   #24
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
I don't quite understand what the extende handles do, and how do they attach.
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 06-13-2012, 06:46 PM   #25
danlehosky's Avatar
Bob, if you need them they should come as part of the package I haven't been able to use my right hand since the incident. This may end up in court. I assume those are from Zip-Dee....
Dan
TAC
Hope is not a plan.
Old 06-13-2012, 08:19 PM   #26
Dan
Gent's.........They do werk.
PFC
"Tahawus"
RLC
John Prine
Old 06-13-2012, 08:28 PM   #27
danlehosky's Avatar
Bob, thanks. I wish I had known about them before the injury.
Dan
TAC
Hope is not a plan.
Old 06-14-2012, 04:00 AM   #28
Dan,
We got the Classic, excited that we now had an awning, first time up, nasty pinch on my salute finger, saw the handles on the Zip site, why the he** don't they come with the awning??
PFC
"Tahawus"
RLC
John Prine
