Old 05-30-2011, 05:08 PM   #1
1961 24' Tradewind
Minneapolis , Minnesota
Zip Dee awning for '61 Tradewind
Will a Zip Dee from a 1974 Airstream work on a 1961, assuming the length is correct? Is the curvature of the body the same?
61 Streamy is offline   Reply With Quote
Old 05-30-2011, 05:33 PM   #2
The arms are for a different curvature, but with a little effort, they can be reshaped.
Work with one of the arms, so that you can see the issue.
Old 05-30-2011, 05:38 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The body style changed in 1969 and the trailer became a little wider, but it should be close. Length might be an issue since trailers in the 60s were mostly even length (yours is 24') and in the 70s they were mostly odd lengths.
Richard
Old 05-30-2011, 06:31 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Be real careful if you are taking the awning off the 74. If the spring is wound it can do some serious damage to you and the Airstream. Also if the length is too long it can be cut down and an upholsterer can cut the awning fabric.
Old 05-30-2011, 07:38 PM   #5
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Andy makes everything sound easy, I love his attitude!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-02-2011, 06:48 AM   #6
1961 24' Tradewind
A call to Zip Dee confirmed different body shapes and lengths. FYI a guy on Mpls Craigslist is selling a brand new, still in the box, awning for 1968-1993.
Old 08-13-2011, 10:39 AM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
what does it take to "cut down"?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-13-2011, 01:25 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
The length of the roller tube can be shortened as well as the awning. Just cut the non spring end. Make sure the shortened length will line up with placing arm brackets over a rib in the body of the coach. The spring for the roller is under tension. It has to be CAREFULLY unwound and wound up again or you can easily get hurt. See my thread "Airstream Owies" if you like photos of blood and broken bones.
The awning fabric should be about an inch shorter on each end than the roller tube, and the aluminum flex guard a little shorter than the roller and a little longer than the roller fabric.
Somewhere I might have the exact dimensions, but maybe someone will chime in here. Or call Zipdee they will give you the specs.
Old 08-13-2011, 02:36 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
...with a hack-saw? is it just a hollow tube at that end?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-13-2011, 05:27 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
A hack saw would work. I used an angle grinder. The whole roller tube is hollow. Just make sure you make the cut equal and square. I measured it at least three times. You can cut it shorter, but not make it longer.
Old 03-27-2013, 08:49 PM   #11
1961 24' Tradewind
Last fall I finally ordered a new Zip Dee awning. A dealer gave me a better price than ordering direct. So I ordered it through the guy who is nice enough to give advice and answers on this site. After providing him my s/n, he knew the EXACT length to order. GREAT! (I thought).
After receiving my long awaited packages and beginning the installation, I found that the tube was too long!!! UGH!!! After exchanging emails and photos it was found to be about an inch too long.
Now I wouldn't have my awning for my first big trip, DANG!
When I spoke to the nice lady at Zip Dee, the first question she asked was how I had measured my coach. Well, I didn't measure it because the dealer knew EXACTLY how long it should be. He didn't have me measure it. She told me that back in the day, not all trailers were built EXACTLY the same.
The dealer was good enough to cover the shipping costs back to Zip Dee and have it fixed. I received my corrected awning in good shape - after my big trip was over.
WORDS OF CAUTION: When ordering an awning, ALWAYS MEASURE YOUR COACH - no mattter what ANYBODY says.
Bent Zip Dee Awning adamjudd Awnings 25 06-23-2012 01:33 PM
Replacing Zip Dee awning canvas webspinner Awnings 23 02-06-2012 06:03 PM
Zip Dee Awning Problems lmcatee Awnings 4 01-08-2012 10:33 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee Awning Repair - Golf Cart Accident jbbaldwin Awnings 0 08-15-2011 01:16 PM
