Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 03-29-2009, 02:04 PM   #1
Bambi Hunter
1977 Argosy Minuet 6.0 Metre
Los Angeles , California
Zip Dee Awning Arm NEEDED!
My 6.0 Metre Agrosy dropped the hitch side (front) Zip Dee spring loaded arm (has the hook end), tie down wheel, and the bracket the tie down wheel screws into. It's somewhere on Interstate 15 near Temecula, CA. If you have one, know where I can get one, or found the one that I dropped, I'd be most grateful to hear from you. Thanks.
Tim
Tim Can is offline   Reply With Quote
Old 03-29-2009, 02:25 PM   #2
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Have you figured how it happened?
Mike Leary is offline   Reply With Quote
Old 03-29-2009, 03:05 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have not used then but I understand there is a salvage yard in AR. called Hair Camper Repairs that has Airstreams and thus ZipDee. Try 205 665 2531 and ask for Sonny. This info came from a junk yard in Fl. last winter while I was looking for some awning parts.
2004 Excursion 4x4
Old 03-29-2009, 03:43 PM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Tim,
If all else fails, you couldprobably get the part directly from Zip-Dee.
Here's a link to the parts list for the curved ones used on Airstreams, Argosys, etc...
Awnings By ZipDee
Good luck.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-29-2009, 07:00 PM   #5
Bambi Hunter
I believe the road vibration loosened the metal screws attaching the bracket to the trailer. With the bracket gone, the arm was sure to follow.
I'll contact Sonny first thing tomorrow. If no luck, I'll contact Zip Dee. Thanks to all for the assistance.
Tim
Old 03-30-2009, 10:17 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
thanks for the caution. I always strap the end arms together - now I will consider a way to secure the middle arm.
Pat
pmclemore is offline   Reply With Quote
Old 03-30-2009, 10:39 AM   #7
arodriguez60's Avatar
2008 27' Classic FB
1959 22' Flying Cloud
fairview , New Mexico
Images: 85
Try out of doors mart they have alot of zipdee parts.
arodriguez60 is offline   Reply With Quote
Old 03-30-2009, 11:41 AM   #8
Mike Leary's Avatar
Ajo , Arizona
I took the middle arm off 15 years ago and have had no sagging problems.
Old 03-30-2009, 12:39 PM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
That number reverse look ups to
Camper Repair Center
8154 Highway 22,
Montevallo, AL 35115
Also
Hare Enterprises
Vaughan
Old 03-30-2009, 12:46 PM   #10
Dan@LED4RV's Avatar
Denton , North Carolina
Tim,
Is this the one you are talking about?
Click here to see it.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Zip Dee Support Arm Air Staked to Ground Bambi_Bandit Awnings 21 08-19-2011 03:23 PM
Zip Dee Awning Chitown AirStreamers Awnings 14 06-09-2011 03:11 PM
Used Zip Dee Awning Needed! cobra93 Awnings 0 12-01-2008 03:20 PM
Zip Dee main arm bar bent- help! kstampa Awnings 13 08-29-2008 05:14 AM
zip dee main arm jammed Wayne&Sam Awnings 12 08-04-2007 04:17 PM
