Old 06-06-2004, 11:23 AM   #1
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Zip Dee Arms Too Long
I replaced the fabric on our 20' patio awning and now I cannot get the arms of the awning to lock in. The arms I'm having trouble with are the two "rafter arms"--the top ones on each end, as well as the middle support arm. They all seem too Long by anywhere from 3-5" depending on how far the lower arms are lifted up. It's definitely beyond the range of the spring tensioner to compress.
Our prior awning was the original 1978 and all the seams had practically disintegrated from UV damage. The Zip Dee man I spoke with said they've now fixed that problem with UV resistant thread. I ordered the replacement fabric for all the awnings straight from Zip Dee. I followed their directions on replacement to a "T". What could I be doing wrong???
TIA for any help!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-06-2004, 11:59 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Could only be a size thing.
Do you still have enough of the old awning fabric to compare?
Uwe
www.area63productions.com
Old 06-06-2004, 12:41 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
dumb question: is the awning rolled all the way down? 3 to 5 inches would seem about one revolution of the awning tube.
john
you call them ferrets, i call them weasels.
Old 06-06-2004, 03:28 PM   #4
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
Thanks for your thoughts, gentlemen. I got it wrong when I originally posted. The top arms seem too long, so it would seem the fabric is too short! Yes, it is unrolled completely. I can take a little slack up from the fabric which wants to droop with gravity, but not nearly enough to account for the shortage of length to connect up the arms. Yes, the fabric from the old one is longer. It had probably stretched over time. With all the seams ripped out, including over the tube, we couldn't really stress it by hooking it up under tension before we removed it to see how that worked.
FWIW, the other fabric replacements fit fine on the side and rear awnings. I'm going to call Zip Dee tomorrow and see if they have any suggestions. I appreciate your thoughts as well. Thanks!
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Old 06-07-2004, 11:28 PM   #5
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
Just FYI for follow-up. I contacted Zip Dee and their solution was to shorten the rafter (upper) arms by the required amount. I hooked up the arm and then compressed the spring all the way, marked the end of the tube that slides over the solid bar then drilled a hole where the pin would be at that position. Final result...they lock up just fine now! Apparently the design of the bars has changed over the years. He had to look up instructions for this procedure based on the year of the awning. I wonder how the new ones work? Thanks again for suggestions. BTW, I remeasured the fabric and they were exactly the same. As I said above our old awning had disintegrated whereever there was stiching and I was measuring to the wrong set of stiching holes.
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Zip Dee Support Bracket LTD93 Awnings 2 12-12-2003 07:51 AM
Adding Zip Dee awnings on other windows... drboyd Awnings 1 09-28-2003 10:08 PM
Zip Dee Repair montanaandy Awnings 2 08-06-2003 12:21 AM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
Zip Dee Awning installation thenewkid64 Awnings 3 04-19-2003 10:08 AM
