Old 01-04-2015, 08:43 AM   #1
jump's Avatar
2013 30' International
lubbock , Texas
Wind speed to roll em up
In Houston today and the wind speeds are expected to be around 15-20 mph this afternoon from the north. We are facing south.
What is the wind speed that you roll up your awnings?
jump is offline   Reply With Quote
Old 01-04-2015, 08:48 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
There is a saying in sailing. If you think you need to take in some sail, it is probably too late. Lesson, be proactive. Personally I am still at that awning paranoid stage. I try to take mine in before the wind might be a problem regardless of the wind speed.
MICHAEL
Old 01-04-2015, 08:50 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I roll ours up whenever I can't feel the windspeed (15mph)...... away from the site or inside sleeping.
Old 01-04-2015, 08:54 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Before the winds pick up...
15-20mph and gusting to ???
I would roll it up, better safe than $orry.
Aaron
WBCCI #XXXX AIR #2495
Old 01-04-2015, 09:41 AM   #5
jump's Avatar
lubbock , Texas
Do ya'll carry wind speed indicators?
Old 01-04-2015, 09:43 AM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I do as others have mentioned - that is, I roll it in whenever I hear it banging around of feel it in the trailer! No idea what wind seed that would correspond to though.
As well, unless it is dead calm and no forecast for weather issues, I roll it in whenver we are leaving the trailer for more than an hour or so just to be on the safe side.
A bit of a pain if I have LED lights clipped to the awning, but a lot less of a pain than replacing an awning!
Brian.
PS - I have also on occasion used tie downs to better secure the awning on a somewhat breezy day. I use extra heavy bungees on the ends of the roller along with and those large spiral things you screw into the ground.
But I still would not leave it out even it tied down that way if we were going to be leaving the trailer for any length of time.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-04-2015, 09:47 AM   #7
jump's Avatar
lubbock , Texas
And what would ZipDee recommend?
Old 01-04-2015, 10:13 AM   #8
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Another consideration is the size of your awning. Little ones handle bigger wind than large ones.
An 8 foot awning on a Bambi with a tie down will be almost indestructable. I put my 20ft up whenever my good friend Bob (nicknamed "Southwind") comes over to my camp.
terryV is offline   Reply With Quote
Old 01-04-2015, 11:06 AM   #9
AWCHIEF's Avatar
Images: 33
Good question, let use know what they tell you.
MICHAEL
Old 01-04-2015, 11:06 AM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Ayup... I use this one.
Aaron
Old 01-04-2015, 11:19 AM   #11
Trailer's Avatar
2015 25' FB Flying Cloud
2016 25' Flying Cloud
Palm Springs , California
From 45 years of sailing experience: "If you're not using it, stow it." A rule we had is if 20 minutes passes and you aren't in it, under it, on it, or through it, then stow it.
Bill
Trailer is offline   Reply With Quote
Old 01-04-2015, 02:39 PM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
From one of the windiest places you'd ever experience:
Agreed about awning size. My TTs have been over 33' with accompanying long units. The following pertains particularly to them.
The wind will whip the awning, a wave-like ripple. Once an arm breaks off it is dangerous. Flailing.
I have used any and all types of securement including up to four guy lines. All can fail. I have kept the awning up in steady 20+ mph winds. If nothing else one is placing a strain on fabric and attachment points. Experiment over.
One can have too much strain in favor of guy lines versus what TT attachment points can handle. Gives new meaning to the word "pop" to hear that fabric whip and metal creak. The trailer will rock due the awning alone.
Unless one is outdoors with the awning in a medium breeze, roll it up. Mine is huge so I understand the reluctance. Higher the wind the harder it is to roll without error, too.
If one leaves the trailer even for short trip roll it up. I inspected damage to a TT where the short trip turned into two hours due to a wreck in traffic. The winds came up and an arm broke. Skin tears, dents and a broken window. Imagine the arm flailing the body at the end of a loose sail.
When one retires for the night, same thing. We were awakened during a flash flood where water came close to the trailer belly. I can just imagine needing to roll that monster in wind and rain at 0400. Trying to get the truck back into the hitch on shifting gravel was hard enough. Who was to know a minor levee had failed?
I love having a full set of awnings. Intact and functioning. Better they are rolled and stored if the question comes up.
Old 01-04-2015, 03:29 PM   #13
mandolindave's Avatar
The chain is only as strong as the weakest link.
If you tie down, your are inviting something else to give.
Keep an eye and ear on the awning. close it when you get nervous, or when there is a weather alert
Close it when you can't get back quick.
I have camped at a place called Wind Gap. Motorhomes would always put there
awnings angled down at half mast, about 3 feet off of the ground. A very quick but not very best way to do it
mandolindave is offline   Reply With Quote
Old 01-04-2015, 05:01 PM   #14
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our four awnings only go out on very calm days. I watch surrounding trees and awnings and if there is movement, we secure ours. Better safe than sorry.
Blue Beltline Insert - $13. for 50' roll COArgosy78 Commercial Listings 8 08-09-2003 09:54 PM
storage area roll-doors Wolf Cabinets, Counter Tops & Furnishings 3 08-01-2003 05:56 PM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
Roll up doors [tampor] ? niftypkg Cabinets, Counter Tops & Furnishings 5 05-17-2002 07:23 PM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 07:22 PM
