02-22-2009, 07:53 PM
Silver Mist
Riverhead
, New York
What size TT have the same size awnings
I'm looking around for a used unit to buy the awning from that will fit our '77 31'
The main awning is just about 21' long, besides another 31' what others may fit?
02-22-2009, 08:36 PM
St. Cloud
Hi Bob - I think Inland has spoken about approximating awning length. Since the awning attaches at the most forward and aft bows, subtract A-frame and both dome-end lengths from overall trailer length. So that comes to almost 9' added to the length of the awning. Will a 21' awning fit a 30' as well as a 31'? I can't quite say that. Anyone?
02-23-2009, 07:15 AM
Corona
The correct Zip Dee size awning, is 3/4 inch shorter than the awning rail. A 31 foot Airstream has a 21 foot awning rail, and the correct Zip Dee awning size is 20 feet 11 1/4 inches.
Different sizes can be used on a 31 foot Airstream, as an example, but the arms "MUST" be attached to a main bow.
Only the owner then can determine exactly what other lengths can be used, since the location of main bows varies from trailer to trailer, except for the very first and last main bow.
Keep in mind the location of windows, access doors, etc.
02-23-2009, 06:09 PM
Silver Mist
Riverhead
, New York
Andy can a longer awning be cut down a few inches/feet?
The next frame would be at 17' 7" is that possible to find on another smaller AS?
02-23-2009, 08:22 PM
1975 31' Sovereign
Houston
Glad you asked. Have never seen it asked before.
Great question. And usual great info from Inland Andy.
Andy was rib/bow placement always the same for every particular model (and floor plan) during a particular model year?
That is; there hopefully was nothing random during a model year in placing the ribs/bows...was there?
Also Andy you mention "main" bows. Are not all bows equal? In size and quality?
I guess some may be broken by windows, hatches etc and would then be "cripple" ribs/bows..?
And isn't there a type of awning that uses down-poles instead of the bow arms? Maybe those were never Zip-Dee.
Whatever those old ones were called, will they attach to the newer style awning rails?
And lastly are all awning rails since 1969 the same (except for length of course) ?
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
03-02-2009, 01:20 PM
Corona
Yes, awnings can be cut down.
Be careful with the springs, as they are under tension.
Not sure what your second question is about.
03-02-2009, 01:33 PM
Corona
The only main bows location that is consistant, is the first one and last one.
Airstream calls them "main bows", but ribs are the same thing.
Most awnings should attach to the "awning rail." If it did not, then I would have nothing to do with that particular awning.
All awning rails that Airstream has used since the early 60's, are exactly the same.
However, they may not be in the same exact location, especially in the early 60's.
If awning arms are used, they must be attached to a main bow for strength. The same is true for a "center support" if used.
Yes, many times Airstream cuts thru a main bow to install a window or an appliance or an access door.
Seldom does that cause a problem, but it's not impossible to happen, especially around the wheel wells.
07-15-2014, 11:08 PM
1969 31' Sovereign
Wilmington
, North Carolina
Found a 19 ft awning can I use it on my 31 foot
I found a 19 ft awning and I was wondering if it had to be the 20 ft and 11 1/4 inches or could I buy the 19 ft?
07-16-2014, 07:35 AM
Corona
The awning "arms" MUST be mounted to a main bow.
A 19 foot awning will not work on a 31 foot trailer, unless you cut it down so that the front and rear arms can be attached to a main bow.
If you use the 19 foot awning, it will rip loose from the shell when the first gust of wind hits it.
07-16-2014, 05:14 PM
1969 31' Sovereign
Wilmington
, North Carolina
Thank you so much for the clarification. I appreciate it and will not be buying the 19 ft awning.
07-19-2014, 12:22 PM
Team Argo
1973 Argosy 26
Clovis
, New Mexico
Thanks Andy, this is awesome information! I am too in the market for a Zipdee awning for my '73 Argosy 26 (which has never seen an awning).
Andy, this may be a silly question, but would I need to install a separate rail or will the rain gutter work? Does zip dee have this hardware or will I have to find the rail elsewhere?
Will I need to reinforce the main bows in any way to support the awning arms?
Life is about courage and going into the unknown.
07-19-2014, 01:04 PM
Corona
1. No.
2. You already have an awning rail on the curb side of your Argosy.
3. Complete hardware is supplied with the awning.
4. All you need to do is order the awning from someone that routinely
supplies them, as well as provide the trailer serial number to make super sure of the size.
5. You should also add a "center support".
6. Nothing needs to be reinforced, as long as the main bows are used.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
What size WH
Gbass |
Water Heaters, Filters & Pumps |
18 |
06-19-2012 09:23 AM |
What size
mok |
Member Introductions |
4 |
05-31-2008 05:50 PM |
what size a/c?
RichardT |
Furnaces, Heaters, Fireplaces & Air Conditioning |
1 |
04-15-2008 08:30 PM |
Twin Size Size
Over59 |
Upholstery, Blinds, Walls & Interior Finishes |
5 |
08-20-2004 10:18 AM |
What size do I need?
Tin Hut |
Batteries, Univolts, Converters & Inverters |
3 |
04-07-2004 06:30 AM |
