Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 10-23-2009, 06:30 AM   #1
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
What brand is this?
not sure if this is a Carefree.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Old 10-23-2009, 07:46 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Does it have a really strange contraption holding it to the side of the trailer, at the bottom? If so, it's probably an EZ Awn.
(No Longer at Inland RV)
Old 10-23-2009, 10:20 AM   #3
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
http://www.airforums.com/forums/f442/ez-awn-by-atlas-enterprises-39931.html
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
richinny is online now   Reply With Quote
Old 10-23-2009, 12:04 PM   #4
Silver Mist
LI Pets's Avatar
Yeh, that must be the brand anyone have any schematic of it?
WBCCI
Old 10-23-2009, 12:19 PM   #5
richinny's Avatar
this is a link to the whole thread.
EZ AWN by Atlas Enterprises???
Ricky
Old 10-23-2009, 06:05 PM   #6
Silver Mist
LI Pets's Avatar
Thanks Rick but that thread kinda died off
Anyone else have info on this one?
WBCCI
Old 10-23-2009, 10:30 PM   #7
Well-Preserved
I've worked on them. What do you need to know?
Old 10-25-2009, 09:21 AM   #8
redhawkerII's Avatar
Profile:  1970 27' Overlander
Altus , everywhere GREAT
Images: 14
Send a message via Yahoo to redhawkerII
Bob, the attachments (one for each bottom) jut out just like the ones in that picture...there are three screws that mount them...then they have kind of a 'tuning fork' design if you know what I mean, you know where there are two sides and the awning has its' extention where it sits in between and is joined....then it can swivel out as the awning is un furled. At the top there are two screws (large) that hold it to the house.
.....Is there another word for synonym? " Life is like a bicycle...to keep your balance you must keep moving." Einstien, 1930...and lastly,-"Go confidently in the direction of your dreams, Live the life you,ve imagined"...Henry David Thoreau
redhawkerII is offline   Reply With Quote
Old 10-31-2009, 06:30 AM   #9
Silver Mist
LI Pets's Avatar
Question
Ok this roller tube is a bit short, what do I need to do to extend it about 3 feet?
Just weld in a tube?
WBCCI
Old 10-31-2009, 07:05 AM   #10
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Find a longer tube. From my experience you can make them shorter, but never longer.
Aaron
WBCCI #2449 AIR #2495
Old 10-31-2009, 03:33 PM   #11
Silver Mist
LI Pets's Avatar
But why not?
WBCCI
Old 10-31-2009, 07:23 PM   #12
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Hi Bob,
There are some issues with welding of aluminum. The ones I would be concerned with in this application are distortion and joint efficiency.
Heat input from welding causes distortion in most cases. This is often addressed in the design process by adjusting joint fit-up geometries, or by using an alternate welding process. While distortion is generally proportional to material thickness, thinner materials are more susceptible to distortion as a rule of thumb.
Joint efficiency is an issue when welding aluminum because most aluminum alloys lose strength when welded. This loss occurs in the HAZ (heat affected zone) of the base materials, or in the weld material itself depending on the alloy being joined. Designers typically compensate for this phenomenon by increasing the joint throat cross section (bulkier if you will).
The other consideration would be appearance as most roll tubes are anodized.
Regards,
Kevin
Experience can be a difficult teacher...You usually get the lesson first...And the instruction afterwards...
Old 11-01-2009, 06:01 AM   #13
Silver Mist
LI Pets's Avatar
ok, not so simple?
what about a mechanical joint- rivet or bolts on tabs-maybe epoxy
How about inserting a sleeve inside the old and new?
Last idea, get a new tube, install the springs etc in the new tube?
WBCCI
Old 11-01-2009, 08:17 AM   #14
Kevin245's Avatar
ok, not so simple?
You could do a mechanical joint if the tube types matched, but connection would need to be very strong, and the awning grooves have to line up.
If it were me I would look for a replacement tube. 3.5" diameter tubes (guessing yours is) are commonly used on today's trailers. You may be able to find one off an old trailer rather than buying a new one. I don't think new ones are all that expensive, but the shipping costs can be prohibitive.
I have picked up several from trailers that were damaged, or no longer in use. The owner's gave them to me as long as I took them down and hauled all the awning materials away.
The only difficulty I had is that 21' long awnings are not that common around here. But they do exist.
Regards,
Kevin
What do you know about this brand tire? Safari-Rick Tires 3 10-25-2007 09:04 PM
Brand New lernerfilm@e Member Introductions 5 03-05-2007 10:45 PM
OK now what brand? McLogger Axles 6 10-21-2006 07:02 PM
Awning brand till Community Polls 19 09-19-2005 10:42 PM
