Old 11-08-2018, 09:32 AM   #1
Pillow's Avatar
Warrenton , Virginia
Vintage Pole and Rope - Best poles to purchase?
I just received new custom awnings from Marti and now need to partner up some decent Poles!
http://martisawnings.com/
Who is making a quality, preferably Made In USA, pole to go with the vintage setups?
FWIW Vintage Trailer Supply is on back order with no ETA at the moment. I'll update when I hear something from VTS.
Any assistance is greatly appreciated!
Trailer: 1948 Spartan Mansion 30'
Tow Rig 1: Hers 2010 Cadillac Escalade ESV
Tow Rig 2: 1971 Chevy C-10 with 5.3 LS and T5 conversion
Soon - Tow Rig 3: 1983 Jeep Cherokee Pioneer (FSJ) with 5.3 LS and SM465 conversion
Daily: His 2007 Cadillac DTS
Pillow is offline   Reply With Quote
Old 11-08-2018, 11:07 AM   #2
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I used adjustable fiberglass painter's poles from Home Depot. Just had to modify the top to fit the grommets on the awning. Easy to adjust to any surface and telescope down for easier storage.
Sam
samb is offline   Reply With Quote
Old 11-08-2018, 11:16 AM   #3
Pillow's Avatar
Roger that Sam.
I've been looking at these adjustable style as well... Not Vintage look, but seem sturdy and would be ultra functional.
https://www.amazon.com/dp/B07BSF1XGT...1-e3e0905aaaad
Adding: I think any of the adjustable poles would be much easier to use in the field as well. Again not vintage, but a little modern with the old
Old 11-08-2018, 06:42 PM   #4
DFlores's Avatar
1968 22' Safari
Buda , Texas
I got mine at Cabelas
https://www.cabelas.com/product/Cabe...E&gclsrc=aw.ds
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 11-08-2018, 08:15 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
https://www.rei.com/product/845322/r...yABEgJng_D_BwE
Alan
Old 11-08-2018, 11:21 PM   #6
rideair's Avatar
I've used different poles over the years, the ones that Marti offers are the best of the best. I would suggest though you find a set of heavy duty stakes (or make them yourself) that are made out of a piece of angle-iron, cut on one end to a long point. The end where the rope would attach has a welded hook on it where you use a large spring to attach the rope too (not the stake). This will allow the awning rope a little give/take on real windy days. I've used this setup at the OBX, NC on windy nights/days (everyone else took theirs down) it will make it through the hardest winds!
Paul Waddell
rideair is offline   Reply With Quote
Old 11-09-2018, 08:12 AM   #7
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Rideair thanks for the hint on the springs we will try that in the future. Sometimes you just need a little give to ride it out. Like the stretchy string in tent poles.
We use bungies and water buckets or garbahe cans at home to give the easy up some give when gusts come thru.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 11-09-2018, 10:16 AM   #8
mykytiukr's Avatar
1965 24' Tradewind
almena , Wisconsin
Poles!
If you want to go cheap until you can get the ones you want, you can use steel conduit. Less than $5 apiece. Cut to length and a bolt through the grommet into the conduit and your rope from the top of the bolt to the stake.
mykytiukr is offline   Reply With Quote
Old 11-09-2018, 01:10 PM   #9
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Spartans RULE!!
“need to partner up some decent Poles!”
I'm happy with 1-1/2” bamboo. Bought 'em at the garden center for $5. Cut to 7', store under bed.
DIY $50 Hillbilly Awning…
Didn't want the glamor of stripes, tassels and scallops, so stitched up $20 worth of blue, “roll-end” sale, genuine Sunbrella with my 1954 Pfaff 130. Any damn fool can sew a tarp. Dog-eared the corners and set the stainless grommets so the tarp drapes with a little fascia to class it up. Good enough for who it's for...
Foot long galvanized nails, nylon clothesline, screw-eyes, rubber cups, the bamboo cut-offs make excellent rope cinches…
And don't forget the stainless sail blocks so you can thread the rail by yourself, standing on a 6-gallon milk basket.
ID:	327414   Click image for larger version
ID:	327416   Click image for larger version
ID:	327419   Click image for larger version
ID:	327421   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 11-09-2018, 03:19 PM   #10
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Glad to hear Marti is still sewing. 100% quality material and work. Have not found poles better than the ones from her in 12 years. Last awning & poles are now 6 yrs old and good as new. When it come to stakes you prob have sand spades & cork screws. Good sometimes. But I also made 3 24 inch X 7/16 rods from solid stainless. Slant cut on driven end and bent round eye on drive end. they drive through loose dirt, gravel and clay and hold. We also put a solar spike light next to each for those dark or "tipsy" nites! Use to be Marti would sew in gromet strips & or nylon tabs to attach lights or hang things, very usefull.
putback is offline   Reply With Quote
Old 11-09-2018, 03:24 PM   #11
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Whoa. Alumininum, never seen that. You can be pretty D sure I'll use that sail block idea just as soon as I find one. Thanks..
Old 11-09-2018, 04:50 PM   #12
chrisetmike's Avatar
1967 26' Overlander
Haute-Aboujagane , New Brunswick
Quick question how big are your awnings? We are also considering a pole type awning but I wonder if it would just be too much of a hastle with our 27' Overlander. It seems like pole type awnings work well on small trailers but I never see them on anything bigger than a Bambi or Tradewind.
chrisetmike is offline   Reply With Quote
Old 11-10-2018, 01:11 AM   #13
1962 28' Ambassador
Mesa , Arizona
Aluminumiumium very nicely done. Now to find all these posts some day.
Hittenstiehl
Old 11-10-2018, 04:58 AM   #14
"Hey, I know you!"
Boog's Avatar
2012 23' Flying Cloud
Irmo , South Carolina
I made a set of awning poles based on the idea that I got from 48Rob at: http://repairingyesterdaystrailers.y...les#reply-2416
My version was a little different because I couldn’t find the copper stub-outs like he used.
https://thisoldcamper.com/
Boog is offline   Reply With Quote
Three pole flag pole holder with poles msmcv51 Airstream Classifieds 0 11-04-2017 11:01 AM
VINTAGE TRAILER AWNING WITH FRINGE (Reproduction Rope and Pole) Support Admin Airstream Classifieds 0 09-20-2013 02:11 PM
12' rope and pole awning goransons Awnings 1 06-20-2011 09:51 PM
Railing for Rope and Pole Awning? oldtrucksrul Awnings 5 06-06-2009 06:41 AM
rope and pole awning pole replacement link please greenrig Awnings 10 05-06-2009 01:52 PM
