Old 08-17-2010, 11:02 AM   #29
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
mine looks slightly different
I had planned on not using this awning...but, now I think I like the look with the Cloud.
I notice that it does not have a center, brace to body, sliding arm. It is just connected and braced at the top and bottom. In other words it does not look like the awnings in the PDF put up here.
If I get this cleared up I will put up some info on the rebuild, polish and new fabric installation.
Any help is appreciated.
Name:	Flying Cloud  Awning.jpg
ID:	108938   Click image for larger version
Name:	Flying Cloud #8010.jpg
Old 08-17-2010, 11:16 AM   #30
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I "think" this awning is an older Carefree... if you unroll the awning, you'll find another vertical brace... this brace telescopes into itself, and then comes out of the resting pocket that's on the lower brace of the awning arm. Take the telescoping piece, and then extend it to horizontal to meet the outreached awning arm.. there's a nubbing inside this extrustion that the brace rests under... that's what keeps the awning tight and away from the trailer.
Kinda hard to explain, but easy once you see it.
Marc
Old 08-17-2010, 12:22 PM   #31
Kevin245's Avatar
This appears to be one of the newer "Vintage" Carefree awnings. Not what I'd call 1st or 3rd generation, but most likely 2nd in the Carefree/A&E era. We have a salvaged one in the garage and it does not have the center lock bars either. On ours the upper hinge arms lock the awning out while it is deployed.
It looks like yours has the quick disconnect feet. If so then its definitely newer era, but still vintage.
Kevin
Eleanor Roosevelt
Old 08-17-2010, 03:57 PM   #32
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
picture up date...now I need parts
Well, I went to the barn and took these pictures. Yep, it has quick disconnect feet. One of the top body attaches has been weld repaired...maybe has something to do with the missing lift/lock handle and the bent arm. Anyone got a lift handle assembly? Anyother parts you see I might need?
The fabric also has a pretty nice segmented metal cover....fabric needs replacement...I hope to use Sunbrella type instead of that nasty Carefree stuff (juast a personal thing.)
Name:	Carefree awning arm handle latch.jpg
ID:	108954   Click image for larger version
Name:	Carefree awning bottom mounts.jpg
Name:	Carefree awning missing arm handle.jpg
ID:	108956   Click image for larger version
Name:	Carefree awning top arm mount fitting.jpg
Old 08-17-2010, 03:59 PM   #33
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
more
some more pics
Name:	Carefree awning bottom arms.jpg
ID:	108958   Click image for larger version
Name:	Carefree awning end roller assembly.jpg
Name:	Carefree awning latch mid arm.jpg
Old 08-18-2010, 07:24 AM   #34
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Looks older than my 72 Tradewinds Carefree. Seems that finding support or parts on the Carefree Awnings is next to impossible. I'm going to need to replace fabric on mine and hate to spend the bucks on a complete new unit from ZipDee
RichHog is offline   Reply With Quote
Old 08-18-2010, 07:39 AM   #35
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I found an old thread entry where our resident sail maker Bob Thompson, near us in Texas, said he could do the sewing work. It sure sounded good to me.
RC
Old 08-18-2010, 10:46 PM   #36
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Hey Inland Andy...
Andy...can you check these photos. I am not even sure now if this is a Carefree. The way the awning arm attaches to the roof by the end of the rail is something I don't see on any other photos. What do you think?
If I go to a Zip Dee can the arms be mounted in the same spots my current awning is?
P.S. ....I like your 20% discount.
Old 08-19-2010, 12:16 AM   #37
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Bump!
I'm gonna bump this thread as I am interested in seeing Andy R.s reply on this awning issue and if it is a Carefree. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-19-2010, 07:20 AM   #38
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Where's Bob Thompson located? There's a few sailmakers here in Houston
Old 08-19-2010, 07:46 AM   #39
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Could not find Thompson's address but I had him repair sails for me in the past and he did a good job.
Old 08-19-2010, 07:50 AM   #40
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
What are you doing with sails in Estancia?
I am trying to find the thread post on the awning/sail reference.....stay tuned.
Old 08-19-2010, 07:54 AM   #41
Lumatic's Avatar
1993 34' Excella
Images: 16
New Mexico has the highest number per capita of pleasure boats in the US. I am a member of the NM Hobie fleet. I also am a landsailer.
Old 08-19-2010, 09:10 AM   #42
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
You must be a politician....no offense intended. The key phrase there is "per capita."
No response from the knowledge base here....I did some more looking and it appears more and more like the awning is an 8000 series, with bent arms for Argosy and Airstream'
Lets see if I can find printed info. Still looking for answers.
PS...I am an old Hobie sailor from Newport Beach (the good old Newport Beach when Hobie had his shop in a garage type building on the Bay.)
Note the top attach of the support arm and the round end caps...not the knobby type shown on Carefree.
Carefree Awning phoney Awnings 7 10-29-2010 09:23 AM
Classified Ad Renewal Help Xstream Forum Admin, News and Member Account Info 2 07-25-2009 01:44 PM
'65 Safari Carefree Awning Help rburditt Awnings 3 07-22-2009 06:16 PM
Rear Floor Renewal - Add Gray Tank? Paul Mayeux Waste Systems, Tanks & Totes 3 03-05-2003 10:29 AM
