03-16-2007, 06:43 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Vintage awnings for windows- ideas needed
I’m in the process of having a custom set of awnings made for my ’68 Trade Wind. I have opted to go with a vintage looking pole and guy wire arrangement for the main awning. I am also having individual window awnings made. I will be attaching the awnings above the window by using awning railings. The only unresolved issue is how to extend the bottoms of the individual awnings. I know one approach is to have the glass hold the awning up, but I would prefer to avoid this for a couple reasons: first, I am not excited about the weight being put on the corning windows, and second, I would like to be able to deploy the awnings while the windows are closed. So what I really need from you folks is a elegant solution to this quandary. The solution must be reasonably priced and not horribly disfiguring to the AS. Thanks.
03-16-2007, 06:49 PM
Naples
Rodney,
Take a cue from the regular awning manufacturers: add a bracket on either side of the window and also at either end of the awning rod. Attach a short aluminum rod to hold the awning in the extended position and add a tie-down strap in the middle with just a little tension on it to hold it in place.
It's like a standard window awning, but no big roller tube or springs. It would look great and be functional as well.
lewster
03-16-2007, 06:54 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Originally Posted by lewster
Rodney,
I was thinking down those lines Lew, can you direct me toward sources for the materials?
03-16-2007, 07:32 PM
Naples
Rodney,
I need more details of your proposed set-up to properly point you in the right direction. PM me if you like...............................
lewster
03-16-2007, 09:02 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Rodney,
My plans are wide open at this point, what would be helpful is knowning sources of hardware that might be useful. If I can look at what is available I think I will be more likely to come up with something that will work.
