Old 03-27-2011, 12:32 PM   #1
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
Question Vintage Awning Question
Apparently the Zip Dee awning has door problems with a 64 GlobeTrotter.
So I have a question with the Vintage awning system. Does the canvas still roll up and store at the side of the AS or does it have to be installed and then removed with each use?
Newbie question
Capt. Paul Mansell
1964 Globe Trotter
1968 Overlander
https://www.airforums.com/attachment...ic34024_12.gif
man7sell is offline   Reply With Quote
Old 03-27-2011, 01:01 PM   #2
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Originally Posted by man7sell View Post
Apparently the Zip Dee awning has door problems with a 64 GlobeTrotter. So I have a question with the Vintage awning system. Does the canvas still roll up and store at the side of the AS or does it have to be installed and then removed with each use? Newbie question
Hi m7s:
If you attach the bottom of the Zip Dee awning front arm installed on a 1964 Globe Trotter with a lynch pin, you can quickly and temporarily remove the bottom of the front arm and swing it out so you can fully open and secure against the Airstream the door-within-a-door on a '64 GT. That will give you ventilation through the screen on the main door, which will still be restricted to opening only 90 degrees. You can just as quickly unhitch the bottom of that front arm to close the door-within-a-door.
Otherwise, most vintage awnings will have to be put up and taken down each time you move your '64 GT. They store inside the Airstream, not on the roof side of an Airstream. Only a very few vintage awnings (none in current production, AFAIK) rolled up into their own cover, which was permanently installed on the awning rail.
Hope this helps you.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 03-27-2011, 04:00 PM   #3
man7sell's Avatar
1969 27' Overlander
So the vintage ones have to be threaded onto the track each time, and taken down every night. I can see where the Zip Dee might be way easier. Decisions decisions.
Indecision may or may not be my problem
Capt. Paul Mansell
1964 Globe Trotter
1968 Overlander
Old 03-27-2011, 07:12 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
It really isn't a problem putting a vintage awning up and down...it only takes 5-10 minutes on a GT after you've done it a few times and have the hang of it - even at a new campsite. Then putting it back up each day is even easier - once you have parked and set your stakes the first time, it really is very simple. You just loosen the ropes leaving the stakes in place and pull out the awning & stow the poles. I can actually do it by myself - no problem. It does help to have a step stool/bench to reach up there - but we found this one we LOVE it's multi-functional around the campsite - it doubles as a table, bench, step stool - it's great!
Shari
Old 03-27-2011, 07:26 PM   #5
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
vintage awning
It's not that big a deal to put up and take down our vintage awning. Once you figure out the system it then becomes quick and easy. We usually leave ours up overnight unless it's windy. Just be sure to adjust your poles so that one end is slightly down to drain rain.
Every time we put ours up we gets compliments. They just look cool.
We got the striped fabric with the scalloped edges.
The only drawback is that we have had to be creative a couple of times because there was no ground close enough to stake the poles well - just concrete. We weighted the poles by tying the ropes to other things - such as two ends of the picnic table we were using. It really looked and worked fine.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 03-27-2011, 07:35 PM   #6
Klatawa (to travel)
Klatawa's Avatar
1965 24' Tradewind
Bremerton , Washington
We had a vintage awning with our Safari. You get pretty good at putting it up & down, when you have a audience or when the wind comes up. I loved the looks of it, but we went to a Zip Dee on our Tradewind (one less thing to pack).
Klatawa
(Dave & Debbie)
1965 24' Tradewind
1965 Chev Carryall
http://s1237.photobucket.com/albums/...ind%20Rebuild/
Klatawa is offline   Reply With Quote
Old 03-27-2011, 08:21 PM   #7
1966 20' Globetrotter
1985 25' Sovereign
johnsoncity , Tennessee
You can purcase a 12 ft awning for a pop uo trailer that stores in azippered bag on the side of your trailer. The only thing you have to pack is the poles and ropes. We have one on our 20 ft Globe Trotter. Have Fun.
donh1 is offline   Reply With Quote
Old 03-28-2011, 11:53 AM   #8
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Shari
Ooh I like that bench/step/table! That's great
via~ AIR Forums App.
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 03-29-2011, 04:22 PM   #9
man7sell's Avatar
1969 27' Overlander
OK the vintage is sounding better and better. So a thought, having been a long time sailor. When the wind comes up or for the night time, if ties where stiched to the end where the bolt rope is (Attchment to the AS) could these be tied up like sail gaskets? Save taking it completly off and on if staying put for a few nights. Just a thought
That handy bench/stool is a must, have to get one of those
Capt. Paul Mansell
1964 Globe Trotter
1968 Overlander
Old 03-30-2011, 01:04 PM   #10
Klatawa (to travel)
Klatawa's Avatar
1965 24' Tradewind
Ties might work but then you'll hear it flapping against the trailer if it's windy, but if your a sailor it might just remind you of being the boat!
Klatawa
(Dave & Debbie)
1965 24' Tradewind
1965 Chev Carryall
Old 03-30-2011, 01:25 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
Yes, you could do that - but I think getting it roll-up neatly so it doesn't flap too much would be way more difficult than restringing each day...I'm thinking the flapping could wear out the awning more quickly too. One more thing, if your trailer is polished the flapping could also mar your polish job.
Yep. An absolute necessity in our book! Love it...I just love multi-purpose items when camping in our small trailer!
Shari
Old 03-30-2011, 02:49 PM   #12
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I think the ties are a great idea.
I just finished building the awning for my Boles Aero and will be starting on the one for the Safari next. It won't be hard to add the ties and makes a good option for when the wind might blow (but also might not), such as at night or when I'm away from the trailer.
I already sewed loops to each end of the awning at the welt that goes into the C channel. With these I can use a hook on a stick to pull the welt through the channel without having to use a stool. As soon as I get my C channel lubricated a bit it will be even easier.
My trailer isn't polished. Do you think that if I put some Nuvite on the awning and let it flap .......................................... ?????????????????
Sam
samb is offline   Reply With Quote
Old 03-30-2011, 04:51 PM   #13
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
I leave our vintage awning up at night until it gets windy. Even my 15x9 is quick to put up and even faster than a zipdee to take down. If the wind kicks up, I can have it detached from the trailer in under 30 seconds. I tend to just take it down if I'm worried about rain. It's easy enough to adjust it for drainage, but I hate having to let it dry before I can roll it up.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 04-01-2011, 11:39 AM   #14
man7sell's Avatar
1969 27' Overlander
Went to the local RV store to see what they have in the way of vintage awnings, guy said they hadn't built them in years.......conversation went on, mentioned that maybe and awning for a pop up would work for me. He said he had just recieved a fax from the warehouse saying they had just one Carefree awning left and was on closeout because they were not going to stock them anymore.
$295 later and it arrived today
Now if it would just stop raining for a minute I could get it installed
Capt. Paul Mansell
1964 Globe Trotter
1968 Overlander
Smoky Mountain Vintage Rally 2011 Silverhobby The Rally Zone 8 05-05-2017 07:36 AM
Awning Hooks Kathleenh 1997 - 2004 Bambi 3 03-14-2011 11:38 AM
