Old 07-19-2019, 06:46 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Tip of Awning Stick
I'm referring to the aluminum rod used to reach the awning lathers and to turn the awning wheel
Somehow I lost the little red plastic tip that goes on the end of the rod. Does anyone have an idea where replacements could be purchased? Or has anyone come up with alternative to the plastic tip?
Thanks!
Old 07-19-2019, 06:56 PM   #2
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
I imagine Zip Dee would send you a couple, and then you could glue it on. Not sure why they don't do that.
I just wrapped some electrical tape around it. Then that came off...and I have just left it bare. Just careful to hit the loop, and not touch/scratch the trailer.
pcskier is offline   Reply With Quote
Old 07-19-2019, 06:58 PM   #3
2007 27' Safari FB SE
Forest Grove , Oregon
Or you can get a can of liquid electrical tape and dip the end in that multiple times until you get the thickness you desire.
bweybright is offline   Reply With Quote
Old 07-19-2019, 06:59 PM   #4
NukeSubSailr's Avatar
2010 20' Flying Cloud
Surry , Virginia
I spent a couple of years being careful and putting the red tip back on every time it came off. Then one day I decided mental health was better than a red tip. I threw it away and have not thought about it since.
NukeSubSailr is offline   Reply With Quote
Old 07-19-2019, 07:03 PM   #5
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
https://www.amazon.com/Piece-High-Te.../dp/B018919IDG
Dept of “OverKill”
@Airstream_Nuts_And_Bolts
Old 07-19-2019, 07:07 PM   #6
pcskier's Avatar
Park City , Utah
Ronnie....no, No, NO. Those aren't red. I'm so disappointed in you.
Old 07-19-2019, 07:14 PM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
https://www.stockcap.com/store/end-caps.html
I think this is the real one. But you gotta order 1000.
Dept of “OverKill”
Old 07-19-2019, 07:57 PM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Zip Dee has them. We were at Alumapalooza this year and picked up several replacements.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 07-20-2019, 09:31 AM   #9
King George , Virginia
Wire Nut
I just glued a wire nut on the end. Worked fine
hotrns is offline   Reply With Quote
Old 07-20-2019, 09:44 AM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
You can buy those at almost any hardware store.
Old 07-20-2019, 09:50 AM   #11
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
50 Piece 1/4" ID High Temp Silicone Rubber End Caps is $45.00 in Canada on Amazon.ca. Black Electrical tape work find.
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 07-20-2019, 12:28 PM   #12
mike28's Avatar
2005 28' Safari S/O
Lakeland , Florida
They are not necessary. I think they are there in case you accidentally poke yourself in the eye!
mike28 is offline   Reply With Quote
Old 07-20-2019, 12:41 PM   #13
Mollysdad's Avatar
Thanks!
You can replace it, but it will fall off again. It takes a beating on the wheel latch. I just left mine off.
However, you can look into "plastic thread protectors" at the big box store.
https://www.homedepot.com/p/8-Red-Ru...2778/204275993
Old 07-20-2019, 01:55 PM   #14
Merkel , Texas
Heat shrink works well. Available in almost all colors. Does not come off easily.
afneill is offline   Reply With Quote
Dip Stick Bill Resseau Mechanics Corner - Engines, Transmission & More... 26 11-09-2010 04:08 PM
weatherstripping didn't stick Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 04-03-2005 11:49 AM
Stick-on-States Stefrobrts On The Road... 21 12-18-2003 02:02 PM
Dometic dip stick? Stinky Refrigerators 2 11-03-2003 07:22 PM
Awning Tip jcanavera 2001 Safari 3 08-29-2003 02:48 PM
