Old 08-04-2010, 05:38 PM   #1
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Temporary disconnection of awning from S/O
I need to make a repair to the top section of the compression seal that goes around the front, top and rear of my slide, but to access it, I would like to extend the slide and not have the awning extend with the slide. This covers up the work area.
Any methods to disconnect the awning from the slide w/o a major mess?
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-06-2010, 06:06 PM   #2
GCinSC2's Avatar
This worked for me.
With slide retracted, one side at a time remove the acorn nuts and bolts that are the pivot point for the arms. Carefully let the arm rotate up and place is on the roof, repeat for other side. Install, pull arm down, insert bolt, tighten acorn nut, repeat for other side.
I just didn't want to make a boo boo on my first awning experience. Don't think I did.
I needed to extend the slide a few inches w/o the awning to re-secure the compression seal on the slide.
S/OS #001
Removall 220 gone? or temporary? JSTOTT Clearcoat, Exterior Paint & Trim 17 04-09-2010 02:41 PM
Temporary License triplenet Title, VIN & Registration 11 12-20-2009 08:10 AM
temporary spare TCL Tires 32 04-23-2006 06:27 AM
Air Pump Disconnection noiva Mechanics Corner - Engines, Transmission & More... 21 01-15-2006 06:09 PM
Temporary pet Pahaska The Pet Forum 11 06-08-2005 11:25 AM
