Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 05-29-2009, 12:45 PM   #1
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Streetside awning
My new street side awning arrived this morning. This project will have to wait a week or so as I am headed to Atlanta on Sunday morning. This is a window awning that will match the patio and bathroom window awning. Sumbrella has discontinued the fabric design that I currently have and I got the last piece from the last roll that Zipdee had.
BTW, the shipping of this awning was about twice what I paid 3 years ago for the patio awning.
ID:	81099   Click image for larger version
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 05-29-2009, 02:50 PM   #2
Profile:  1975 Argosy 24
Malakoff , Texas
That is one shiney rig dude!
kennethowens is offline   Reply With Quote
Old 06-14-2009, 07:41 PM   #3
Phoenix , Arizona
Images: 62
Thanks for the compliment.
Now it's time to install the street side awning. The first thing to do is mount the awning rail. I have limited clearance from the top of the windows to the bottom of the kitchen exhaust, so finding the correct spot is critical. I marked and then installed a line of blue painters tape. The bottom of the tape will be the top of the awning rail.
Problem #1 - Zipdee does not supply the Olympic Rivets for the awning rail. I used most of my supply in Albuquerque filling all the holes when I removed my old A/C unit. Rivets are on order from VTS and should be here by the end of the week.
Question #1 - I am going to space the rivets 6" apart on the rail. This is more or less what the factory did with my patio awning rail back in 75. Does that sound right to everyone?
Question #2 - Should I pre drill the holes in the awning rail and then drill the holes in the skin once it is in position?
To be continued...
ID:	82311   Click image for larger version
Richard
Old 06-14-2009, 07:58 PM   #4
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i think you need to catch the body ribs.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 06-14-2009, 08:09 PM   #5
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I agree, unfortunately mine AS is over 1,000 miles away or I would take a look at it for you. IIRC the ribs are about 24" on center or so, maybe hold the rail up, mark the rib locations, drill the holes for those and then go back and put the intermediates in.
Aaron
WBCCI #2449 AIR #2495
Old 06-14-2009, 08:24 PM   #6
Commercial Vendor
Profile:  Corona , California
To be continued...
First as many rivets as possible should go into the main bows.
Using 4 inches between the rivets plays it pretty safe, especially on the curb side.
Scatter the holes out and then mount the rail with either Cleco's or #8 screws.
Then drill all the holes you wish.
Completely remove the rail, and remove all the shavings.
Apply a bead of Vulkem sealer on the backside of the rail, making sure that bead covers every hole, and is continuous from one end to the other.
Install the rail with the rivets. Some sealer may sqeeze out of the bottom of the rail, so clean it up asap.
Lastly, install a bead of Vulkem on the top side of the rail joining it to the shell.
If you use Vulkem, it does not set up very quickly, so that buys you time.
If you use Sikoflex, it does cure out in about 1 hour, so you must quickly clean up any boo boo's.
You might check out the curbside awning rail and make sure it has plenty of rivets, and that it's properly sealed.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 06-21-2009, 12:34 AM   #7
Phoenix , Arizona
Images: 62
Back to work on the awning.
Lots of rivets to hold the rail in place. The pneumatic rivet gun makes things a lot easier. I used the dremel to cut off the extra stem and round the heads slightly. I will finish them off later with a rivet shaver.
Then all I had to do is add the arms and install the roller. The travel latch goes on tomorrow...
ID:	82657   Click image for larger version
ID:	82659   Click image for larger version
Richard
Old 06-21-2009, 07:52 AM   #8
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Images: 65
Richard, it looks GREAT!
Airstream Posters & Tee's
by Micheal Joseph Depraida
WBCCI No 8892 | VAC | KC2TQU
ArtStream is offline   Reply With Quote
Old 06-21-2009, 08:03 AM   #9
Commercial Vendor
Don't forget the Vulkem on the top side of the awning rail.
Also, your supposed to wear rubber gloves when doing work on the outside of that trailer.
If you get finger prints on that great polish job, the owner will "get you."
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-21-2009, 08:34 AM   #10
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Nice job Richard. I agree wiff Andy,rubber gloves a must.The owner will track you down from your fingerprints left in that polish job and KICK YOUR BUTT.
Really nice Richard
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336
Mikethefixit is offline   Reply With Quote
Old 06-21-2009, 11:14 AM   #11
Phoenix , Arizona
Images: 62
Added the all important travel lock this morning. One last photo of both sides deployed.
BTW, I did not intend to do this awning this year, but I found out that Sunbrella had discontinued this pattern. The window awning was made with the last piece on the last roll that Zipdee had in stock.
ID:	82699   Click image for larger version
Richard
Old 06-21-2009, 11:33 AM   #12
76sovereign's Avatar
Profile:  1976 31' Sovereign
ozark , Missouri
Luckeeeee
Luckeeeee! Gosh! She looks AWESOME! Great job man..
my new street side awning arrived this morning. This project will have to wait a week or so as i am headed to atlanta on sunday morning. This is a window awning that will match the patio and bathroom window awning. Sumbrella has discontinued the fabric design that i currently have and i got the last piece from the last roll that zipdee had.
Btw, the shipping of this awning was about twice what i paid 3 years ago for the patio awning.
http://airstreamremodel.blogspot.com
http://vimeo.com/kani
76' 31' Sovereign
76sovereign is offline   Reply With Quote
Old 06-21-2009, 11:34 AM   #13
ozark , Missouri
It is for a fact! What did you use to shine that baby?
76' 31' Sovereign
Old 06-21-2009, 02:02 PM   #14
Phoenix , Arizona
Images: 62
Thanks for the compliments on the trailer.
When I bought the trailer several years ago the PO had polished the trailer and it looked pretty good. The trailer was beginning to dull and the PO told me (several times) that he thought I should polish it again. I thought that he should polish it again since he started it, but I got no where with that suggestion.
Santa brought me a Cyclo for Christmas and I bought the Nuvite. It took a few passes and a lot of hours with different grades, the last being "S". My plan is to hit it again every winter with just "S" to keep it looking good.
Richard
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 3 04-21-2009 06:57 PM
Streetside Upper Awning Rail - Why? Cracker Awnings 14 03-18-2009 01:21 PM
Bambi II streetside windows yukionna 1964 Bambi II 2 04-14-2005 11:05 AM
Awning Rail Seal? & Awning Wardinbb Awnings 1 09-23-2004 10:57 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 04:07 PM
