Yesterday I visited the Confined Space Rally at the Eagle Creek Overlook just outside of Portland, OR. Francoise and I had a great time and we got to meet Janet and Gary, Stephanie and few others in person... not just as forum avatars.
Of the serveral things I saw on other AS that caused me pause... was the the front mount point for my Carefree awning is in the wrong spot. It looks like one of the PO either got a deal or wanted the "one size bigger" awning. <insert your favority Tim Allen Home Improvement quipe here>
The front part of the awning upper brace is mounted in the upper wrap-around and not into the metal arch support between the window by the door and the front end cap. I'll see if I can dig up a pic.
I looked at the awning (I pulled everything off to get at the blasted Silicone sealer) and the roll with the awning material looks to be long tube of alumuim... so can you cut it down by a foot, remount the caps and then retension it ?
Man I don't know if yo can cut those down... Being spring loaded as they are.. You best bet would be to call care free and see what they say.... How long is it? Does it even fit in the rail on your roof?? You may have to get a new awning to change it the mount point.. looks to be about 1-2 ft long.. Is the back mounting point in the right spot...??
Jason
They can be cut down. You will need to remove the roller from the arms, and remove the rear insert, and remove the awning fabric. Then you can use either a chop saw or sawzall to cut the excess length from the tube. Cut the same amount from the awning fabric, and sew it back so it doesn't unravel.
You can move the mounts, slide the awning fabric back in place, and reinstall the rear insert.
Can you tell I've done this before?
AGREED!
I've had to do this on several occasions when the factory or the owner gave the wrong info that produced an over sized awning (unfortunately, you can't do that when they are too short). There is usually one spring, but even if there are 2 springs, they can be easily removed. Trim the tube by the length required to place the bottom bracket directly over the first vertical rib, and then have the fabric trimmed and hemmed by the same amount.
As it is a Carefree, you simple slip the fabric out of the channel in the roller tube, cut it, and then replace it later when it is the matching length.
__________________ Lew Farber -Certified Master RV Tech (currently on Forums sabbatical) WBCCI #1032/VAC (assoc) #1032 AIR # 10325 CHARTER MEMBER: FOUR CORNERS UNIT
Thanks for the guidance... look like I get to use my horizontal metal cutting bandsaw. Any day you *have* to use it... is a good day.
The awning frabric is toast so I'll just order a new on in the correct length. Any thoughts on the "standard" lengths?
The rear connection is in the right location... the front is just messed up. Now I just need to find something to cover the holes for the upper brace connection.
It's on a curved piece of the end-cap so I'll have to figure out some way to curve the metal and make a plate of some sort.
Oh.. and one more thing... they riveted 15" extension to the the front end of the awning rail. Of course it doesn't line up 100% and left a big kink in the frabic. Removing the old awning took about an hour of trying to get the fabrice to slide out. Grrrr...
Apply an aluminum patch over the holes, riveting it in place. Put some vulkem around the patch, and put a small dab of it on the olympic rivets to keep water out.
Awnings are generally 10 feet shorter than the stated length of the trailer, your awning should be 13 feet. It would be a really good idea if you measured the tube after you cut it down to proper length.
