09-05-2013, 10:30 PM
2002 31' Classic
Houston
Rusty Rear Awning Retention Struts – SOLUTION
Several years after purchase of my 2002 ASCL 31’ I noticed that the raw 3/16” steel rod retention struts which hold the rear awning open were rusting, including their push-on retention caps (quality???). Over the years I’ve tried to source identical rods in stainless steel, but 3/16” stainless rod was never available when the matter was on my mind.
About a week ago I was in “Fastenal” on another matter; the rusted struts crossed my mind so I ask if they had any 3/16” stainless steel rod; they did, so I purchased one 3’ length (description = 3/16” X 3’ 304 SST Round 47722). I then sourced stainless steel “Cap Nuts” with #10-24 threads from Home Depot (PN32361).
Using the OEM struts as a template, I fabricated same (added ~1” to length) from the stainless steel rod, cut #10-24 threads and rounded the opposite end, sanded “shop rash” with 400 grit wet/dry and polished with “Mother’s Mag & Aluminum Polish” from an auto parts store (that stuff will polish ANYTHING). It took 2 to 3 hours.
So now I have stainless steel struts that will never require maintenance to go with my stainless steel vent, furnace and hot water heater covers; maybe I should source some stainless steel sheet to kill the aluminum filiform corrosion …………. naw, that would add too much weight.
09-05-2013, 10:42 PM
1999 34' Excella
Hillsboro
Nice ..... pics?
Peace and Blessings..
Channing
WBCCI# 30676
09-05-2013, 10:48 PM
2002 31' Classic
Houston
Originally Posted by cwf
Nice ..... pics?
It's midnight, no light, I'll take some in the morning.
09-06-2013, 09:45 AM
2011 30' Classic
Kingwood
I did something similar last week. My acorn push nuts were rusting, so I cut 10-24 threads on the end of the support rods and added the stainless steel acorn nuts from Home Depot. I put them on with some blue thread lock.
Thanks to withidl great solution, I may replace the support rods with stainless steel at some future date.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
09-06-2013, 01:18 PM
2002 31' Classic
Houston
Awning Strut Photos
Awning Strut Photos per request:
09-08-2013, 08:48 PM
1999 34' Excella
Hillsboro
Nyce! Thanks!
Channing
WBCCI# 30676
12-26-2013, 01:09 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Withidl,
How did you make the bend, just clamp it in a vice then bend it? I thought about making some of these, but thought the metal would be weakened and break if bent that sharply.
Thanks for sharing your info!
Alan
01-03-2014, 04:40 PM
2002 31' Classic
Houston
Originally Posted by A W Warn
Withidl,
Thanks for sharingour info!
Alan, it's just a cold bend in a vice and using a hammer to make it "tightly" 90 degrees. Stainless steel is tougher than regular steel, but still bends fairly easily. Make the piece a little too long on each end and then shorten after the bend.
The hardest part was finding the correct diameter rod as it's not carried in the normal hardware stores.
