Old 06-19-2015, 08:37 PM   #1
2007 23' Safari SE
1972 25' Tradewind
St Cloud , Wisconsin
Rope and pole awning design
We had an awning made for our 25' Tradewind. It is 15' long, as long as the channel on the trailer, and extends 8' out. It sags too much in the middle and towards the trailer. We are thinking of having it shortened to 10' long. This awning has a pocket that we can slide a rod in the entire length. We tried 1-1/4" PVC, but it adds too much weight and adds to the sag. Would we better off to put a stretched rope through that pocket? Or there some sort of aluminum rod available that would not sag?
Any advice on this project would be greatly appreciated.
deer4200 is offline   Reply With Quote
Old 06-19-2015, 08:49 PM   #2
1974 Argosy 20
Kooskia , Idaho
Replace it with a Zip Dee which was the standard Airstream awning back in 1972.
I am sorry, could not resist. Giggle. I just like Zip Dee's.
I honestly wish I could help but really have no helpful ideas for you at all.
Old 06-19-2015, 11:06 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I am assuming you are not using a tensioned roller, that you are making a tent out of your awning. Are you trying to get by with poles at each corner of the awning with two ropes and stakes driven in the earth as supports for each corner pole? If that's what you are doing, add a center pole that is a foot or so taller than the corner poles, to create some slope.
Alan
Old 06-20-2015, 07:32 AM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
center pole, milk baskets... KISS
We travel with milk baskets that are stacked as a ladder to insert and pull the the canvas through the awning rail, and three 7 foot 1-1/2"D bamboo poles, one of which has a tennis ball end to support the middle canvas.
The rigid poles are stored in the under-bed bin with the milk baskets which serve a multitude of function including guest seating.
The center pole is positioned so as to prevent the door from brushing the awning. The milk basket that supports the center pole serves as the coffee table.
That's how "Us Hillbillies" roll...
ID:	241132   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 06-20-2015, 09:12 AM   #5
Zil
egg harbor city , South Jersey
Be careful, the plastic milk crates will break while you stand on them. I have had the bottoms burst through.
Zil is offline   Reply With Quote
Old 06-20-2015, 11:12 AM   #6
67 Globetrotter
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
. What type of AC is on your roof please.
KrisE MN is offline   Reply With Quote
Old 06-20-2015, 12:20 PM   #7
hamiltonmj's Avatar
1965 17' Caravel
2013 Interstate Coach
Opelika , Alabama
Neat. What is the awning fabric? I've thought about using extendable paint poles for the awning poles.
Mike Hamilton
WBCCI # 2766
2013 Airstream Interstate (Darth Vader)
1965 17' Caravel (R2D2)
hamiltonmj is offline   Reply With Quote
Old 06-20-2015, 09:28 PM   #8
NO HUMBLE OPINION
reply
KrisE ME, My AC and shroud are original 1968 Armstrong TAC 110.
hamiltonmj, The awning fabric is from Sunbrella. If you shop for "roll ends" you can get it really cheap. We paid twenty bucks for enough fabric to make two awnings, We stitched the awning on our fifty year-old Pfaff. The bamboo poles were $4 each from the landscape nursery.
Zil, Thanks, I know what you mean. In the olden days, when Milkmen could lift six gallons, the crates were rectangular. I hoard the old welded steel rectangular milk crates, and have a few old plastic rectangular ones that are as tough as Delrin (if you know that plastic). I think the modern square baskets are junk because there is so much loss expected from theft.
ID:	241192   Click image for larger version
ID:	241194   Click image for larger version
Old 06-20-2015, 10:39 PM   #9
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Simple and elegant. Nicely done.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 12-05-2016, 10:46 AM   #10
nickclifford's Avatar
1972 31' Sovereign
felton , California
hi all, my '72 Sov doesn't have an awning, and I'm not inclined to fork out a small fortune for a factory spec type, Zipdee? is that it... anyways I believe they're kinda pricey. So wondering how these work ? any feedback would be great, I need to do more research ..!
http://www.vintagetrailersupply.com/...-p/vts-400.htm
nickclifford is offline   Reply With Quote
Old 12-05-2016, 11:29 AM   #11
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Vintage Awning
They work fine, just a bit more work to put up/down.
You can get one quicker and cheaper from Awnings by Kristi:
dfoster@bellsouth.net
Have bought two from her and been very pleased with the quality.
You can select color, pattern and size.
Measure your awning rail to get length and width is up to you.
Get some good quality telescoping poles.
BambiTex is offline   Reply With Quote
Old 12-05-2016, 02:42 PM   #12
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
Hey jus to let you know Zip Dee isn't the only company that makes awnings for our trailers. I just installed a new Dometic Awning last year they make curved arm hardware kits specially for airstream trailers. My 27 foot awning only set me back like 1300 and has the aluminum protector for when it's rolled up.
bellastream is offline   Reply With Quote
Old 12-05-2016, 02:45 PM   #13
1969 31' Sovereign
Auburn , Washington
ID:	276402 here is what the dometic awning looks like.
Old 12-05-2016, 03:02 PM   #14
1969 31' Sovereign
Auburn , Washington
838100D015 is the part number for the Dometic Airstream hardware kit it covers years from 1969 thru 1985
Pole and Rope Awning falcon-N-Air Awnings 9 05-27-2013 05:43 PM
Rope and pole awning-at my wits end. AWCHIEF Awnings 21 10-09-2012 12:24 PM
12' rope and pole awning goransons Awnings 1 06-20-2011 09:51 PM
Railing for Rope and Pole Awning? oldtrucksrul Awnings 5 06-06-2009 06:41 AM
rope and pole awning pole replacement link please greenrig Awnings 10 05-06-2009 01:52 PM
