Old 06-30-2007, 09:37 AM   #29
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by Silvertwinkie
You know, I may really consider this more seriously. I took a look at the Safari and Airstream seems to have put the top awing rail on up top already on the streetside. So looking at your methods, I may be able to skip some of the steps. I may put a call out to Zip Dee and see what that price might be and how brave I'm feeling. But I'll be honest, it took this from for sure having someone else do it to, hey, I may give it a wack! If that rail isn't the right one, it may be for an actual full size awning. Might go that route too.
Hey Twink
The awning rail on the street side that is opposite of the one that they use for the patio awning is there for another patio awning. It does NOT work for the window awnings. You still have to add a new awning rail for the window awnings on the street side. I tried to use this rail when I installed my street-side window awning on the 19CCD, but other than being too high to be effective for shade, the arms are not properly bent to allow you to use the top rail.
Old 06-30-2007, 10:12 AM   #30
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Lew, thanks for clearing that up. I had seen that extra rail. I thought it was also mounted upside down as well...
Richard
Old 06-30-2007, 10:21 AM   #31
_
function of the extra rail?
Originally Posted by lewster
The awning rail on the street side that is opposite of the one that they use for the patio awning is there for another patio awning...
i agree the rail is of the style used on the patio awning...
and too high for the narrower awnings...
but are you sure that's WHY it is installed?
my guess is that the ridge it creates, serves as a rain gutter/channel...
and provides a site/relief line for the white roof panel.
without it the white panel is easily seen and distracting.
has ne1 ever asked/confirmed it's function with a/s corp?
now that the main ribs are 3 pieces there is another channel section/seam there too...
does it interact somehow with the rid/skin/channel junction on each side?
cheers
2air'
Old 06-30-2007, 10:55 AM   #32
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Just like Alexandria
The original reasoning and or knowledge for/of the standard road side railing awning install has been lost in time.
Just as, much of the old design and engineering which has been carried over to the new Airstreams has.
The other guy told me to do it that way?
(IMHO)
Michael
ArtStream is offline   Reply With Quote
Old 09-07-2007, 03:32 PM   #33
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Just had Airstream (factory in Jackson Center) install a streetside and rear Zip Dee awnings on my 06 Safari. Saw this configuration on a 23' Safari earlier this year and thought they looked great. The street side is lower than the curb side, but it really shades the trailer.
tsunami is offline   Reply With Quote
Old 12-21-2010, 02:13 PM   #34
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Loose Roadside Awning
Just finished reading this excellent tutorial by ArtStream. In #11 he states that after you have the awning centered that you install small SS screws in the awning rail. Am I correct that these are installed in the ends of the rail? I've discovered that my awning - installed at Jackson Center in Oct '09 is loose and sliding in the rail. There are no screws in mine - it appears that they crimped the ends of the rail to hold the awning centered. I tried crimping the rail a bit more at each end but it is still loose and will slide about an inch towards the rear of the trailer. Suggestions?
Al - K4GLU is offline   Reply With Quote
Old 12-21-2010, 02:26 PM   #35
_
yes a stop screw at each end is a good thing.
stainless with a bit of sealant or anti seize on the threads,
and watch for depth, make sure the threads are fully engaged INSIDE the rail tube.
alum screws may also be satifactory,
but the ones on my unit are stainless.
they are on all 5 awnings and 1 of them need work loose a few years ago,
but was REtightened. they can fall out.
cheers
2air'
Old 12-21-2010, 02:58 PM   #36
Thanks 2air. I installed screws in each end but the awning is still loose. Will keep a close eye on this and unless someone else comes up with an idea I'll leave it for the factory to take care of next May. Just out of curiosity I checked the back window awning on mine and no screws in it - the ends of the rail are crimped together to hold it in place. At least it's tight and won't move. Maybe because of the fact the screws can work loose this is the way they're installed by the factory now.
Old 12-30-2010, 09:06 PM   #37
Just from my experiences:
We pulled down roadside and the front and back end ZipDee awnings off of ours during polishing and for repairs. The slats and rails all have screws in the ends to keep the slats from coming out. Since the slats on ours are about an inch shorter than the rails mounted to the AS, there is a little movement allowed but the screws keep the slats from working out of each other and the main rail. As long as you have something to keep the slats from coming out, it should be ok (crimp, screws, etc.).
Artstream,
Thanks for the detailed process. It helped us when we were taking ours up and down.
Old 12-31-2010, 12:47 AM   #38
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Happy to help
Old 05-29-2016, 10:25 PM   #39
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
I'm going to install a road side awning and need to know the correct position of the arm castings
paddle whisp is offline   Reply With Quote
Old 11-18-2017, 06:12 PM   #40
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by ArtStream View Post
Following the instructions I turned the arm head casting to preload tension to the awning roller spring.
Then the head castings are bolted to the arms and lock-tite applied to the Stainless Steel bolts.
Resurrecting a 11 year old thread:
I'm going to remove the awnings on my Excella pretty soon. When I re-install them I will need to tension the roller springs, but I have no experience at this.
Could someone elaborate a little more on how this tensioning is done. I am asking specifically about street side and rear window awnings, not the patio awnings.
Alan
A W Warn is online now   Reply With Quote
Old 11-18-2017, 06:38 PM   #41
Central , Mississippi
The ZipDee site had instructions but they were hard to find. The left side arm has the spring. I unbolt it at the wall and usually twist it enough so the awning has just enough tension to wind itself up. Use caution because if you let it get away it will whip the crap out of everyone and everything in its path
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-18-2017, 07:08 PM   #42
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I looked at ZipDee's website a few times, but did not find the instructions. I'll look some more.
I was hoping to find an instructional video, but no luck yet.
Alan
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Awning Heads Up!!! JaceBeck 1999 Safari 39 04-25-2006 05:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Awning gwrimmer General Motorhome Topics 1 11-07-2002 11:59 AM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
