Old 04-23-2012, 03:36 PM   #1
1971 27' Overlander
1976 Argosy 24
1975 31' Sovereign
Oro Station , Ontario
Retrofitting a used ZipDee awning
Greetings all,
First post of many I suspect. I am the proud owner of a 1971 Overlander. This trailer is a complete restoration project and is coming along very nicely. It was abandoned in the forest in 1993 and sat there until I had the brilliant notion that I could fix it up....So far so good! Anyway I am retrofitting a used Zip Dee awning to it that I can make work but it would be better if it was about three inches shorter...of course! Is it possible to shorten the tube on these units? Has anyone done this before? I am replacing the material so that won't be an issue.
Wayne
rcscanada is offline   Reply With Quote
Old 04-23-2012, 03:51 PM   #2
1981 31' Excella II
New Market , Alabama
I suspect you can remove the spring assembly and cut the tube. I don't know the details for the spring and how it is housed. I wonder if someone has an exploded view of how all the parts fit together. I do know you need to unwind the spring before you start messing with it or you could get hurt. The hard part is getting a perfectly square cut without a lathe. It would be nice if there was an online shop where you could just buy replacement canvas for these awnings.
Perry
Old 04-23-2012, 04:36 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
It's not difficult to shorten the tube. Drill out the rivets and remove the non spring end. Measure very carefully and then measure again and then cut the tube. Reinstall the end cap and rivet into place. You will also have to cut the cover slats after measuring carefully. Since you are replacing the fabric have it made to the new size. Here is a link to an exploded drawing of the parts. http://awningsbyzipdee.com/media/19b...04ffffd523.pdf
Good luck, Dan
Old 04-23-2012, 06:58 PM   #4
1971 27' Overlander
1976 Argosy 24
1975 31' Sovereign
Hey Dan,
Thanks for that info. I think that is all I will need to give it a go! Sounds like a good project for this weekend. I did see a youtube video on unwinding the spring.
Old 04-23-2012, 07:03 PM   #5
webspinner's Avatar
Menlo Park , California
Here's a link to the original Zip Dee instructions:
http://www.airforums.com/forums/f442...tml#post481948
And here's a link to the blog post about the new awning we made for our Zip Dee:
Tin Pickle Adventures: New Awning - sewing and metal repair
Wishing you the best with your restoration!
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 04-23-2012, 07:41 PM   #6
1971 27' Overlander
1976 Argosy 24
1975 31' Sovereign
Thanks for all the info. Is there anything out there on safely unwinding the spring? The throat severing example has me a little nervous. I see how to wind it and put it all back together but there isn't anything on detensioning it that I have seen.
Old 04-23-2012, 07:47 PM   #7
1981 31' Excella II
Leave the arm attached just unwind it slowly and don't let go of the arm.
Perry
Old 04-23-2012, 08:05 PM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Perry
For a photographic explanation of the above post see this thread:
http://www.airforums.com/forums/f483...ies-51182.html
Old 04-23-2012, 09:33 PM   #9
1971 27' Overlander
1976 Argosy 24
1975 31' Sovereign
Thanks Perry, I downloaded a great explanation from the zipdee site. Thanks for the photographic insight. Really hoping I don't have anything to add to that thread...
