Old 10-08-2014, 02:29 PM   #1
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Removing the Upper Brackets for Caulking
Is it safe to remove the upper brackets while the awning is rolled up to facilitate caulking the brackets?
Kelvin
KJRitchie is online now   Reply With Quote
Old 10-21-2014, 01:33 AM   #2
jonplayers's Avatar
Terrace , British Columbia
Hmmm I'd be careful!
I think you have to let the tension off of the springs first.
Find a manual for your awning and follow the steps.
I've just removed my awning as it was the source of a leak.
Name:	ImageUploadedByAirstream Forums1413873183.119551.jpg
jonplayers is offline   Reply With Quote
Old 11-06-2014, 09:20 AM   #3
Natty Lite's Avatar
Mandeville , Alabama
Jon & KJ,
My bracket is loose also! Did you have to use a larger bolt? Are there threads behind the exterior? I'm hoping that I just lost a bolt and I have to seal & replace fasteners(bolts)!
Natty Lite is offline   Reply With Quote
Old 11-08-2014, 11:39 AM   #4
jonplayers's Avatar
So on my awning it was possible to undo the bolts and calk behind with out undoing the torsion. There was a place for a coder pin. I highly recommend getting a manual for the particular model you are working on.
Old 02-19-2015, 12:35 AM   #5
Originally Posted by Natty Lite View Post
Jon & KJ,
Still need help?
airman805 is offline   Reply With Quote
Old 06-05-2015, 09:32 AM   #6
2007 19' Bambi
Park City , Utah
The rear bracket on my awning is loose on a 2007 Bambi. I never saw a response on if you can tighten or need a bigger screw. Anyone have advice?
Chucke is offline   Reply With Quote
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 09:34 PM
Removing old caulking Nellie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-02-2007 12:08 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 11:47 PM
Attaching Awning Brackets Mike Rhodes Awnings 7 10-30-2002 08:35 PM
