Old 03-16-2011, 08:47 PM   #1
1977 Argosy Minuet 6.0 Metre
deland , Florida
Removing awning carefree
i see how to unscrew the poles from the banana wrap and i see how it will slide out of the track up top. my question is do i need to do somethign so the awning will not roll around when i pull it all the way out?
Jason and Miranda 1966 safari/1970 chevy c-10
http://i183.photobucket.com/albums/x...eAirstream.jpg
386kustoms is offline   Reply With Quote
Old 03-16-2011, 09:13 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There will be tension on the roll because of the loading of the spring(s) inside of the roll. You must remove that tension before you start the removal process. Failure to do so can cause damage to your Airstream and to you.
I have done this with my ZipDee, but I have no experience with a carefree awning. Hopefully someone who has done this will explain the procedure.
Richard
Old 03-16-2011, 09:16 PM   #3
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
Why are you removing it?
Get right or get left, and have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Old 03-16-2011, 09:17 PM   #4
deland , Florida
im going to be re clearcoting the trailer.
Old 03-17-2011, 05:29 AM   #5
Kevin245's Avatar
This thread may help. A word of caution when dealing with awning torsion springs. "Be Careful".
http://www.airforums.com/forums/f442...light=carefree
Good luck,
Kevin
Eleanor Roosevelt
Need 1 '70s carefree straight/support arm. flyinbrian Awnings 3 04-15-2011 06:00 PM
Awning Hooks Kathleenh 1997 - 2004 Bambi 3 03-14-2011 11:38 AM
Removing underbelly to clean, repair water lines Airdaddy Ribs, Skins & Rivets 2 02-17-2011 07:30 PM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
