Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 06-23-2009, 07:45 PM   #1
Profile:  1976 24' Argosy 24
Milford , New Jersey
Removing a Zip Dee Awning
How does one go about removing the Zip Dee Awning? Do I try to slide the fabric out of the metal wrap or do you try to get the wrap out of the awning rail? Any advise would be appreciated. Thanks, George
Gkiesel is offline   Reply With Quote
Old 06-23-2009, 07:59 PM   #2
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 835
The last strip of aluminum is crimped onto the fabric.
Best to remove the fabric with that one strip of aluminum.
Then on ground can open the crimps
If you order new fabric, they will ask you if you want a new strip crimped on.
DO IT!
Saves you many problems.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator
klattu is offline   Reply With Quote
Old 06-23-2009, 08:00 PM   #3
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
State of , Washington
Airstream Registry
Send a message via MSN to goransons
You should be able to remove the end screws and just slide out one segment of the metal while someone holds the drum, once back on the ground if you're going to reuse it you can reassemble. Don't forget to unwind the tension spring before you cut things loose.
Scott & Megan
WBCCI #8671 Oregon Unit
Visit our Blog- http://safari8671.blogspot.com
63 PARTS NEEDED
bathroom heat register cover
63 refer, or at least the original door insert
1 12v hehr motor (working) w/ or w/o fan blade
goransons is offline   Reply With Quote
Old 06-23-2009, 08:05 PM   #4
Liberator
klattu's Avatar
Images: 835
See the screw head at end?
Take it out and it will slide
Click To See Me Wet
Old 06-24-2009, 08:02 PM   #5
So you open the awning enough to undo the arms and unwind the spring, the roll it back up, take out the screw and slide the whole works out? Thanks for the picture! Seeing is believing. George
Used Zip Dee Awning Needed! cobra93 Awnings 0 12-01-2008 03:20 PM
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Zip Dee Awning Adjustment handn Awnings 3 04-28-2006 06:42 PM
Zip Dee Awning Chitown AirStreamers Awnings 11 04-12-2005 08:17 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
