Old 12-03-2009, 04:14 PM   #1
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Removed awning...
How do I repair the holes along the top and bracket holes?
Silicone? Presently they are all are covered with duct tape
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 12-03-2009, 04:55 PM   #2
Ottawa , ON
Rivets? Big 'uns, ah reckon. With Vulkem in the hole first. Or a li'l aluminum patch, if them holes is 2 big.
Old 12-03-2009, 04:57 PM   #3
Kevin245's Avatar
Say No To Silicone!
Use rivets and vulkem.
Eleanor Roosevelt
Old 12-03-2009, 06:06 PM   #4
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
I KNEW IT!!!
RIVETS and Vulkem was kinda hoping it was something I had already worked with ...BUT NO...Learning Again... My guess, its another learning curve of type of and size of rivet question. I have become quite the expert in drilling out rivets
Thanks Yall, Cynthia
Old 12-03-2009, 06:10 PM   #5
1972 25' Tradewind
Madison , Wisconsin
Rivet
I repair small holes by drilling them out then put in a dab of vulkem or similar butyl based sealant. I then put in an olympic rivet and grind off the stem with a dremel tool. Not as neat as a rivet shaver but it works quite well.
The nice thing about rivets is that you can drill them out again when/if you decide to replace the awning. Even though I left the gasket on some olympics I see the logic to removing them before use.
Smokin Camel is offline   Reply With Quote
Old 12-03-2009, 06:12 PM   #6
Ottawa , ON
Oops, yes, thanks for reminding me, Smokin'!
If water is to be kept from seeping in, Olympic rivets or bucked rivets MUST be used. The little hole in pop rivets lets water through.
Old 12-03-2009, 06:16 PM   #7
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
If the hole is not too big, I would use 5/32 Olympic Rivets. They have no hole to leak like a standard pop rivet and the head can be shaved to look like an original bucked rivet.
Richard
Old 12-03-2009, 06:34 PM   #8
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Is the standard "pop rivet" the type you can putrchase at the big box stores? You know, the kind with the hole in it?
Old 12-03-2009, 07:05 PM   #9
Ottawa , ON
Yep!
Old 12-03-2009, 07:40 PM   #10
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
see how smart I is??
Old 12-03-2009, 07:47 PM   #11
Kevin245's Avatar
And to think, most us didn't catch on until we had a couple hundred posts!
I would definately use olympic rivets for this application as well.
Kevin
Eleanor Roosevelt
awning, exterior restoration, hole
Removed the carpet! Santart Land Yacht/Legacy Motorhomes 12 09-13-2009 06:53 PM
Armstrong AC Removed---Now What???? Heirstreamer All Argosy Trailers 6 06-17-2009 02:07 PM
Removed TV Antenna... JK3500 Roof 9 10-22-2008 12:18 PM
Removed the door... gotohatteras 2006 Safari 7 06-30-2007 07:10 PM
Has any one just removed.... tyndalelady Upholstery, Blinds, Walls & Interior Finishes 4 01-26-2006 12:12 PM
