Old 11-20-2010, 06:11 PM   #1
bennyg's Avatar
1973 23' Safari
New Albany , Indiana
Removed AE awning> is frame and roll reusable?
my awning was a source of various window leaks, simply bc AS sat forever and behind the awning roll became a makeshift compost and water stood and trickled down for years and caused vulkem around windows to be compromised. I removed awning roll and frame but I had to cut the material. The rail that awning slid in is riveted on roof and I plan on removing and riveting holes. Can this roll and frame be reused or should I scrap it? Thanks
ID:	115628   Click image for larger version
bennyg is offline   Reply With Quote
Old 11-20-2010, 06:19 PM   #2
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Don't scrap it!!
There is a demand for the A&E hardware among the vintage crowd. Myself included. Unfortunatly just bit too short for me.
Post it on the classifieds and it will bring joy to someone and cash to you.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 11-20-2010, 06:22 PM   #3
bennyg's Avatar
1973 23' Safari
Thank you Tom
Old 11-20-2010, 06:29 PM   #4
x
XXXX , XXXX
Benny you may want to rethink that idea. It is nice to have an awning and it also helps for resale value. A&E makes replacement fabric anfd can be purchased from any RV dealer. If it is perfectly functional then replace fabric, reinstall and with regular maintenance it will not cause you any problems. More than likely lack of maintenance and age caused the vulkem to fail.
wasagachris is offline   Reply With Quote
Old 11-20-2010, 06:36 PM   #5
bennyg's Avatar
1973 23' Safari
Thank you Chris I will definitely hold on to it. One handle is missing, other than that everything else looks good. Beside the fact I do not know how to operate it!
Old 11-20-2010, 06:48 PM   #6
Kevin245's Avatar
Hi Bennyg,
You'll find varing opinions on awnings. Some love them, some don't, but the arms and roll have value and it would be a shame to see them get scrapped.
As for removing the awning rail...any penetration in the shell is a potential leak point so the riveted holes will still require periodic attention.
Best of luck,
Kevin
Eleanor Roosevelt
Old 11-20-2010, 08:26 PM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you have the original Armstrong A/C, be sure and check the hole where the power cables and freon lines go thru the top of the trailer. I had a terrible leak, thought it was the awning but was the A/C. Water would stream down the curb side window. Took a lot of vulkem but finally got it stopped.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 12-10-2010, 08:59 PM   #8
Hi there ... I have just bought my first airstream ever, a 1964 22' safari which has the same structure for the awning. It is however missing the inner strut on the right hand arm... I wonder if that part could be the same in yours ... Assuming you haven't sold them already .... Obviously it would make more sense to sell the entire contraption if you are able ... Just enquiring.
Best
Rob
Robert Burns is offline   Reply With Quote
Old 12-10-2010, 09:00 PM   #9
Sorry ... Didn't read the other replies ... Good on you for keeping it ... Best rob
Removed a 1970 Zip Dee awning WILDRTEXAS Awnings 9 04-25-2010 08:21 PM
Removed awning... WILDRTEXAS Awnings 10 12-03-2009 06:47 PM
How to roll out awning? offroader Our Community 16 09-21-2009 08:24 AM
zip dee awning will not roll floridartist Awnings 6 07-19-2009 12:04 PM
awning doesn't roll up, spring ? JohnTF Awnings 11 10-24-2007 09:53 AM
