Old 10-15-2008, 09:31 PM   #15
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Doug,
Nice work
ArtStream is offline   Reply With Quote
Old 10-16-2008, 08:26 PM   #16
j_c_c's Avatar
1969 31' Sovereign
Los Angeles , California
Looks clean - Did you also need a special tool for the rivet nuts you used for the two mount screws? Also assume you didn't need any access from the back then? Are both nuts floating in the new sheets, or did one hit the c-channel, or both? Just visualizing all I'll need before I tackle this next weekend....
Thanks!
j_c_c is offline   Reply With Quote
Old 10-17-2008, 05:59 AM   #17
crdouger's Avatar
1960 22' Safari
Rockford , Michigan
I bought the rivnuts and the assembly tool from the same place. Several places had installation tools that cost $70-$90. The one I used was only about $10. It's really simplet. It's a large hex nut with a slot in the side of it to hold the rivnut in place and then a hex head bolt that pulls the rivnut tight and collapses the wings of it. See this link.
Plusnut Blind Fasteners - Find Plusnuts Fasteners at Cardinal Components
When I used the tool and compressed the nut it pulled up real nice and tight. I was able to go through the c-channel as well as three layers of aluminum, so I feel like it's structurally pretty sound.
Doug
I've been helped so many times on these forums, it's nice to be able to help somebody else back.
crdouger is offline   Reply With Quote
Idler Arms Fim White Mechanics Corner - Engines, Transmission & More... 5 10-06-2004 10:43 PM
Replacing Awning Arms beachmpk Awnings 7 10-05-2004 01:28 PM
Reattaching banana wraps? Mike B Belly Pans & Banana Wraps 2 05-10-2004 04:44 AM
Awning arms Doug Diepenbrock Awnings 1 08-06-2003 02:04 PM
