Old 06-18-2010, 09:08 PM   #1
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
Reattaching awning?
Is there a way I can reattach this myself that you guys can tell me about? My awning has come completely unattached from the cover thing (it came this way from previous owner). It appears to be crimped all the way down so I'm thinking if I open that up, insert awning, and recrimp it should hold..maybe. I thought I'd better ask for suggestions first though.
MonaxLisa is offline   Reply With Quote
Old 06-19-2010, 05:17 AM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Everything you need to know is here. This same thing happened with my '75 Sovereign.
You probably had the same failure I had, eg, the 70s original edge roll used a cotton cord that has since rotted and disappeared. If so, you'll need to insert new cord, repair the edge of the slat, and the re-crimp the fabric in the slat.
BTW, from your photos is looks like your slat didn't have enough crimps in it to begin with.
Zep
Old 06-19-2010, 07:46 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Good job ZEP, but here is another way that I use quite often on other types of awnings with the same or similar problem.
1. remove the outer 2 slats from the aluminum awning cover
2. separate these into 2 pieces by removing the outer retention screws and sliding them apart
3. repair the lead edge channel as per Zep's instructions
4. after inserting new poly cord (commonly known as pneumatic tubing) into the awning pocket, slide the repaired slat with the lead rail onto the awning.
*NOTE* if the original outer slat is too badly deformed and will be difficult to slide the fabric thru, you can usually switch these slats and use the rail from the second slat to run the fabric thru. This will allow you to slide the damaged one thru aluminum, which should be easier with no snags.
5. position the awning up near the remaining aluminum cover that is still attached to the trailer, and slide the remaining slat into both the upper (trailer) and lower (fabric with last slat) sections.
6. replace the end screws
7. remove the rear arm from the trailer and re-wind the spring per Zip-Dee instructions.
8. you are DONE!!!!
Any questions?????
Old 06-19-2010, 11:02 AM   #4
MonaxLisa's Avatar
thank you both!! I'll let you know how it works out
Reattaching screen-to-main door latch funkill Doors & Locks 11 06-05-2016 12:01 PM
reattaching stabilizer funkill Jacks, Stabilizers, Lifting and Leveling 16 03-20-2010 10:25 PM
Reattaching bottom awning arms securely... crdouger Awnings 16 10-17-2008 05:59 AM
Reattaching banana wraps? Mike B Belly Pans & Banana Wraps 2 05-10-2004 04:44 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
