Old 01-03-2012, 05:35 AM   #29
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by richinny View Post
when i clicked on the fabric link i got this message from NORTON:
"Malicious Web Site Blocked"
I get a 404 error.
Old 01-03-2012, 06:10 AM   #30
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by overlander63
I get a 404 error.
The link as posted has an extra http in front of the address.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 01-03-2012, 08:59 AM   #31
richinny's Avatar
2011 34' Classic
that fixed it for me.
http://www.fabricmaven.com/stripes-baycrest-pacific-fabric-c-258-p-1-pr-17079.html
can a mod fix that link please?
Ricky
Old 01-03-2012, 10:31 AM   #32
Central , Mississippi
Done
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-03-2012, 10:43 AM   #33
Well Preserved
1993 21' Sovereign
Originally Posted by barts View Post
Well, it looks like this fabric works for both webspinner (Barbie) and I:
STRIPES - BAYCREST PACIFIC*::*Stripes*::*Sunbrella Awning and Marine Fabrics*::*FabricMaven Upholstery Fabrics
so that's going to be our new awning .
Now to see how to fix up that aluminum wrap.... and exactly how to determine the right length of awing.
- Bart
The Zip-Dee awning is officially 10 feet shorter than the trailer length, so your 25' Tradewind would take a 15' awning. The actual fabric length would be something like 14', 11 1/4".
Old 01-03-2012, 11:04 AM   #34
Maniacal Engineer
barts's Avatar
Menlo Park , California
Hmmm. Our trailer has the battery access door right where the lower rafter arm would attach with a 15' awning - so it looks like the fall back plan was a 14' awning. The attachment piece on the top of the trailer is definitely setup for a 15' awning.
In the picture you can see how the awning didn't roll up correctly until we increased the tension on the spring.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 01-03-2012, 03:04 PM   #35
- Bart
From lookin at the photo, i tend to agree with a previous post...some of the metal slats look to be missing. That alone would make the awning too short.
Old 01-03-2012, 03:13 PM   #36
dznf0g's Avatar
Oswego , Illinois
I don't think they are missing. I looks like they added a track BELOW the awning roll to mount the fabric. It appears there is a rain gutter (with fabric channel???) above the awning not being used?????
Either that or the whole assembly is mounted too high. See the fabric going straight up the side to the roll.
Wait! Is your aluminum metal slat just riding on top of the fabric? The fabric should fit in a slot at in the last slat so the slats are actually part of the awning roof when deployed and roll over the fabric to cover it when stowed. If the fabric AND the aluminum slats are BOTH attached to the trailer, that's why your material seems short.
What am I missing here?
That track has been added. It goes right across your vista window. More close up pics of the tracks and slats and top fabric mounts will clear this up. You may not need new fabric afterall if that's the case.
-Rich-
Old 01-03-2012, 05:12 PM   #37
Maniacal Engineer
barts's Avatar
The aluminum slats didn't roll up correctly in this photo; this was very difficult to do until I (this last weekend) disassembled the stuck main arm and got everything freed up and increased the tension on the spring; after that, the aluminum slats would roll up correctly as in the video posted earlier in this thread.
The awning needs to be replaced; much of the stitching is failing due to the use of (apparently) linen upholstery thread rather than the Dacron (polyester) thread one is supposed to use with Sunbrella.
The fabric was clearly not done by Zip Dee.
=- Bart
Bart Smaalders
Menlo Park, CA
Old 01-03-2012, 05:17 PM   #38
dznf0g's Avatar
Oswego , Illinois
But it appears in your last photo that the fabric is connected directly to the wall?????
Not sure about the old ones but not at all like mine is set up.
-Rich-
Old 01-03-2012, 05:44 PM   #39
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I did not take time to examine each post, so this may have been already covered.
The extra handle to extend the awning is worth it's weight in gold. I had great difficulty extending the main arms fully so the rafter arm will attach.
If you flip the roller over from left to right the fabric will be right side up. But then you will have to take the fabric off the alumaguard and re- insert it the right way. That means you will also have to pull the alumaguard out of the track on the coach body and thread that in again too.
Old 01-03-2012, 07:21 PM   #40
Originally Posted by Lumatic View Post
...If you flip the roller over from left to right the fabric will be right side up...
I'm thinkin the trailer is upside down...was it ever in a South America Caravan?
Old 01-03-2012, 07:30 PM   #41
dznf0g's Avatar
Oswego , Illinois
Then the springs will wind the wrong direction. Fabric must come off both the wall and the roller....or do the spring assemblies come out the end of the tube easily? I've only ever disassembled an A&E.
-Rich-
Old 01-03-2012, 08:38 PM   #42
Lumatic's Avatar
1993 34' Excella
Images: 16
- Bart
You can attach the lower anchor point for the main arm above the compartment and shorten the arm. It works and I have seen it done, but I think it looks better with a 14' awning and a regular size arm.
Any suggestions for RV parks in NoCal for long term stays? norma Solo Streamers 5 01-06-2012 02:42 PM
What are the bracketd under our awning arms? Skatiero Exterior Restoration Forum 3 10-07-2011 05:37 PM
"The Long, Long Trailer" GeocamperAS Hitches, Couplers & Balls 14 05-10-2011 07:02 PM
Refinishing window arms '76 Globetrotter kentuvman Windows & Screens 8 04-24-2011 07:54 PM
