Old 05-07-2007, 08:16 PM   #1
1974 25' Tradewind
Muscle Shoals , Alabama
Problem with awning
I just bought a vinage 74 Land Yacht Tradewinds and I cant figure out how to let the awning down. Does anyone have any tips? This is my first Airstream and I would appreciate any info anyone could give. Please don't assume that I might think what you could tell me is unimportant. I am absolutely GREEN when it comes to this stuff. I tried to pull a couple of levers to let the awning down, but they would not move.
Matt
chuman70 is offline   Reply With Quote
Old 05-07-2007, 08:24 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Depends on the awning......... On a Zipdee there is a release knob at each bracket at the ends of the roller. On a EZ try lifting each arm straight up an inch or two to get it to release.
Old 05-07-2007, 08:26 PM   #3
1974 25' Tradewind
How do I tell which type it is?
Old 05-07-2007, 08:35 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
They are usually stamped somewhere, usually on the end cap or arm bracket at the top end of the extension arm. I think (but am not sure) the factory used EZ awnings that year. There are a few aftermarket awning possibilities too. The bad news is if it is original and you need parts they may no longer be manufactured. In fact I think EZ is out of business.
Post a photo and someone who knows a little bit more than me should be able to help you out at least to pin down what you got.
Old 05-07-2007, 09:24 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The awning doesn't just let down. It's held up with a big spring inside the drum around which the fabric is wound.There is supposed to be a pull tap of awning fabric in the center. You pull on that to start the awning unwinding. If it weren't for the spring, you couldn't retract the awning when you were done with it.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-08-2007, 12:01 AM   #6
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Post a picture of it and you will get detailed instructions and everything else you wish to know about it.
Thats what happens here.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 05-08-2007, 12:11 AM   #7
1974 25' Tradewind
I'm new to the forum. How do you post a picture?
Old 05-08-2007, 08:08 AM   #8
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
To post pictures:
Click on reply and scroll down to bottom of text box.
Click "go advanced" add text to message window and then scroll down.
Click "Manage attachments" A separate window will pop up.
Click "browse" Then select the file to be uploaded. Be sure that the photo is appropriately sized. 1024 x 1024 pixels (or smaller) and no more than 300 K. You may select several photos to upload at the same time by repeating the last step.
Click "Upload" After pics have loaded close the pop-up window
Click "submit reply" to mount the text of your message - photos will automatically appear in post.
Mel
Mel is offline   Reply With Quote
Old 05-08-2007, 10:54 AM   #9
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Don't do anything that seems hard or a little tough.
Done correctly, it is very easy.
I broke the brake loop off doing it wrong, and pulling like crazy.
If photos are not up here latter today, will get you some.
klattu is offline   Reply With Quote
Old 05-08-2007, 10:57 AM   #10
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Does the ends look like this?
Oh...Zip Dee is still open
Old 05-08-2007, 08:24 PM   #11
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Old 05-08-2007, 09:36 PM   #12
1974 25' Tradewind
Help with a non Zip-Dee awning
I posted last night with a question about how to unroll a 1974 Tradewinds awning. Not sure what happened to that post. It is not a Zip Dee awning and I can't get it to budge. It looks like the canvas may be in rough shape, but I can't get it open at all. I' am totally new to Airstraming as I have only owned my 74 for 4 days now. It is in need of some minor restoration and I really need some help on how to undo the awning so I can let it out. Any suggestions?
Old 05-08-2007, 09:55 PM   #13
CanoeStream's Avatar
St. Cloud , Minnesota
Is it a Carefree? Link to scans of manual in post 5. Some Airstreams back in the 70s and most of the Argosy trailers had these. Carefree is still in business I think. My Argosy awning is about 7/8ths intact and can be jury rigged with Hold-Awn straps.
5 meter Langford Nahanni
Old 05-08-2007, 09:57 PM   #14
1974 25' Tradewind
I honestly do not know.
awning polycord size sovereign Awnings 5 04-23-2012 11:38 AM
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
Ripped my Awning ... Porky Pig Awnings 1 04-17-2004 06:45 AM
Found new A&E awning Dave-O Awnings 4 10-21-2002 08:15 PM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 09:16 AM
