Old 08-09-2015, 08:55 AM   #1
2015 30' International
FREDERICK , Maryland
Power Awning stopped working
My Zip Dee Power awning stopped working (2014 30' International Serenity) after my last trip ended several weeks ago. Didn't notice it until I was doing some post trip cleaning. Fortunately it was in a closed position. The OPEN green light is steady. I have checked the fuse, etc. power is OK to everything else. Used it several times on our month long trip to NV, UT & CO. When I hit open or close I can hear some faint clicking but no movement. The power awning "motherboard" under the sink, is all lit up like a christmas tree as usual.
Any ideas before I call Zip Dee and/or drive it 3 hours back to the dealer, drop it off and come back in a week or two to pick up? That equals 2 wasted Saturdays as I am not quite yet fully retired.
Still within 1 year warranty on trailer and 2 year warranty on awning.
Bought the trailer off the dealer lot and did not want the power awning for this reason, but it was already on the trailer and the trailer had everything else we wanted.
Doc Foster is offline   Reply With Quote
Old 08-09-2015, 09:34 AM   #2
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Interested in this thread as I have ordered a 2016 with the power awning. Keep us posted on what went wrong.
TinCan
graysailor is offline   Reply With Quote
Old 08-09-2015, 09:44 AM   #3
Remax gal's Avatar
2014 27' FB Eddie Bauer
Lake Placid , Florida
Yep, I'm interested too! We have the power awning and absolutely love it
Laura & Tom
Let the good times roll!! Laura
Remax gal is offline   Reply With Quote
Old 08-09-2015, 11:47 AM   #4
After pushing OPEN and CLOSE a few times, I noticed that it stays steady green on STATUS now???
Old 08-09-2015, 11:33 PM   #5
TinCan
graysailor's Avatar
2016 30' Classic
I would have to dig out my notes but as I recall there is a sequence of buttons to push that resets the system. They are buried in the manual somewhere so you might try that.
TinCan
Old 08-10-2015, 04:07 AM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Images: 8
The issues with the power awning operation are not new. I specifically did NOT order the power awning. One less electonic/power device toleave one stranded in the woods. Great when they are working....
Old 08-10-2015, 07:20 AM   #7
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I agree - the convenience and novelty is great, but on balance, I feel simplicity is best in many instances. Also less expensive both initially and in the long run too.
I suppose that a reasonable compromise is at least to have a manual option if the electronic wizardry fails - I don't know if that applies in the case of power awnings or not? Hopefully it does.
Most power tongue jacks for example are so designed in anticipation of electrical failure.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-10-2015, 07:24 AM   #8
2015 25' FB International
Bay Area , California
I'm interested interested in this topic too, about to take possession of a 25 FB with the power awning. Like you, didn't want the option but am buying off the dealer lot...
Looking at the Zip Dee manual, they emphasize using the 'close' function after any power interruption. Could it be as simple as disconnecting power, reconnecting and starting with 'close'? They also repeatedly provide their phone number for support, 800 338-2378. Please do let us know how things turn out, I'm sure there are several others who are curious.
WkendWarrior is offline   Reply With Quote
Old 08-10-2015, 07:30 AM   #9
switz's Avatar
2014 31' Classic
Images: 8
Check at the base of the awning support arms where the power wires come through the skin and into the pole to see if there is a grommet around the wire or just tape. If it just tape, as done on the 2013 and into 2015 models, the wires insulation may be cut and shorting on the knife edge of the skin from making the hole.
If the wire is cut, then the inside skin has to come off to access the wiring to make the repairs.
Many power awnings without the grommets were shorted out on the dealer's lot after many demostrations of the power awning.
Old 08-10-2015, 10:49 AM   #10
gwg
gwg's Avatar
2015 30' Classic
Glen Mills , Pennsylvania
Our 2015 Classic awning would extend then the one end would keep rotating about 1/2" in each direction. Would not stop, had to retract it back in. Had it fixed at JC, minor adjustment per the tech. I agree not bullet proof and could have stuck with the manual one we had on out last two.
Nice when it works but stinks when doesn't.
gwg is offline   Reply With Quote
Old 08-10-2015, 11:17 AM   #11
SKP46015's Avatar
Pay your money ...take your chances... I'll stick with the traditional manual awnings...
but... good luck in getting that one fixed...
Ed
94 30 Ft. Front Kitchen Excella
99 GMC 2500 6.0L Ext.Cab. 8ft Bed
ARE Shell Topper
SKP46015 is offline   Reply With Quote
Old 08-10-2015, 11:29 AM   #12
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Call Zip Dee, they are great folks.
It may be a simple fix.
From what I have seen of their products, they would not have sold it it they didn't think the kinks were out....
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-10-2015, 11:45 AM   #13
2014 27' FB International
Santa Rosa , California
Check the voltage level on your inside voltmeter, it needs to be a solid 12 volts or higher, FYI there is a recall on the original control boards, and last but not least check all connections as compressed as this is also an issue
NatandGregg is offline   Reply With Quote
Old 08-11-2015, 04:45 AM   #14
switz's Avatar
2014 31' Classic
Images: 8
The wiring issues mentioned in post #13 are reflective of the push them out the door fast versus make sure they are done properly mentality that has taken over Airstream.
We have a major rebuild job to correct the the shower installation in the 23D. Taking it back to the factory is not an option and the dealers would be constrained to Airstream parts that would not fix the issue.
Dash Air Fan, Power window and Power Seat Stopped working alvinator Land Yacht/Legacy Motorhomes 3 07-13-2014 09:22 AM
Dometic has stopped working on AC? Pacerized Refrigerators 6 04-21-2009 07:28 PM
Porch light stopped working MK 1967 Lights - Interior & Exterior 5 08-24-2008 09:15 AM
The furnace stopped working ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 13 02-24-2006 02:04 PM
Tail Lights Stopped Working dpope 2003 Safari 8 04-05-2003 12:22 PM
