Old 06-22-2016, 09:36 AM   #1
1968 22' Safari
Dorchester , Illinois
Post and Rope awnings
OK, got our awning from Marti and installed for first time today (in driveway). My 68 Safari had the channel to slide the awning into however, it was in poor shape, screw holes, tar and dents/dings so I spent a morning working a bolt (with the head removed and a "wing" welded on so I could tap it along) cleaning an reshaping the channel. Worked OK but more difficult than it should be. I will order and install a marine pulley but feel I need to lubricate the channel as well. I saw on here that one person used WD40, any other suggestions on a lube to use?
edited to correct name.
Missed-Em is offline   Reply With Quote
Old 06-22-2016, 12:22 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I used spray silicone on mine.
CRH is offline   Reply With Quote
Old 06-22-2016, 12:27 PM   #3
2016 25' Flying Cloud
Holly Springs , Mississippi
WD-40 is reportedly 70% kerosene. It's a good anti-rust agent but not so great as a long-term lubricant as it tends to get "gummy" and attracts dirt. For your application a silicone or dry lube may prove more useful.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is online now   Reply With Quote
Old 06-22-2016, 01:25 PM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
I suggest McLube:
http://www.rvplus.com/mclube-sailkot...FZWMaQodHyAH2A
BambiTex is offline   Reply With Quote
Old 06-22-2016, 02:34 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
What is a Marine Pulley and how do you install that to help with awning installation? I would like to add one of these awnings to the Caravel.
Stephanie
Old 06-22-2016, 02:50 PM   #6
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Many folks install a cheek block pulley at the end of the awning rail (like this http://www.westmarine.com/buy/harken...-block--253336) and use a rope to pull the awning through the rail.
However you can achieve something similar (not quite as elegantly!) using a eye-bolt and pulley (available for less than $5 at most hardware stores. Take a look here https://youtu.be/McBT_6nw4RM
martin300662 is offline   Reply With Quote
Vintage style awnings (martys awnings) LUCKYDOGNOLA Airstream Classifieds 0 03-24-2014 11:04 PM
rope and pole awnings dcribbins Awnings 0 04-08-2012 10:56 AM
12' rope and pole awning goransons Awnings 1 06-20-2011 08:51 PM
Railing for Rope and Pole Awning? oldtrucksrul Awnings 5 06-06-2009 05:41 AM
rope and pole awning pole replacement link please greenrig Awnings 10 05-06-2009 12:52 PM
