Old 08-03-2012, 06:55 AM   #1
2004 30' Classic
Peterborough , Ontario
Out of round main tube
We have another newly found problem.
Our awning has a bent roller tube.
Does anyone have a simple cure.
We were told that a new tube was the repair.
Russ
dirtturner is offline   Reply With Quote
Old 08-03-2012, 07:07 AM   #2
Central , Mississippi
If it's a Zip Dee, only bowed and does not have a kink, you may get lucky. Zip Dee has some instructions on their site on re-straighting the main tube. I can say that mine resisted all efforts to straighten by simply using 3 mildly heavy dudes. I ended up placing a ladder under each end with the bow curving upward, then I used a front end loader to push down and straighten it out.
Be safe...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-03-2012, 07:54 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
ZipDee has instructions here:
http://awningsbyzipdee.com/media//DI...ecffffd524.pdf
Richard
Old 08-03-2012, 09:09 AM   #4
dznf0g's Avatar
Oswego , Illinois
I got lucky as well. I placed a single ladder at the low point of the U shaped upturned tube; tied down one end to a lawn tractor, and pulled down (bounced and hung) from the other end. I stopped before it was absoultely straight, but it is working fine, with little wobble when retracting and deploying.
-Rich-
Old 08-03-2012, 09:39 AM   #5
2004 30' Classic
Thanks to all
The bend does not have a kink, there is about a 1.5 inch wobble. We will try the applied preasure repair and see how that goes.
Thanks again
Russ
Old 08-03-2012, 09:43 AM   #6
dznf0g's Avatar
Oswego , Illinois
Study, study, study where the exact center of bend is. You don't want to end up with a "W".
-Rich-
