Old 05-24-2011, 08:41 PM   #1
1972 31' Sovereign
Valdosta , Georgia
No spring to my Zip Dee
New to AS but I assume my ZipDee Awning is supposed to be spring loaded and retract itself???? Any suggestions/advise on how to get the spring back in my step (awning)?
GaCamper is offline   Reply With Quote
Old 05-24-2011, 08:55 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The tension may need need to be adjusted.
Awnings By ZipDee
Richard
Old 05-24-2011, 08:56 PM   #3
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Yes, it should.
Possibly the spring has unwound, or broken.
Check the end caps, look for a missing cotter key first.
You can rewind it kinda easy.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 05-24-2011, 08:57 PM   #4
1994 30' Excella
Mississauga , Ontario
Check the Zip Dee website. When the awning is out you need to push on the roller to start it rolling up. Once it starts to close it should keep going.
Al
Al and Jean
TAC ON-3
Old 05-24-2011, 09:05 PM   #5
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
I installed a new main fabric on mine.
The spring load was opposite end that has the lock, as in photo.
seems like I twisted about 15 to 17 times, but it was years ago.
Zip Dee may have instuctions available.
Click To See Me Wet
1972 Argosy 24'...
Old 05-24-2011, 09:13 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
The starting point for a patio awning is one turn for every foot of length of the awning plus 7 additional turns. A 31 foot trailer's awning should be around 22 feet long, so the starting point would be around 29 turns.
BE CAREFUL! That is a lot of tension, one slip and you can have some serious damage (trailer and you).
Richard
Old 05-25-2011, 11:25 AM   #7
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Thanks for the advice, all of you. Our main is also reluctant to roll up, but will do so with some pushing. If the spring is wound OK, perhaps some lubricant would help? If so, where shall I put it and what kind shall I use?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 05-25-2011, 04:29 PM   #8
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
ENTRAPMENT
Click To See Me Wet
1972 Argosy 24'...
Old 07-01-2011, 08:00 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
We bought and older trailer with a Zip Dee that was a little reluctant. At the International rally a nice guy from Zip Dee cam and looked at the awning in the campground. He suggestede using spray Silicone almost everywhere to lubricate the sliding parts and the ends of the rollers. He stated that the more you use this thing the better it will work. He also stated that if you can get it to roll all the way up with a little nudging that is tight enough on the spring. He suggested not trying to tighten the spring. Basede on the theory that it was tight enough when it installed and it will be too tight with it extended if you tighten it more. The springs stick and break, but do not weaken much with time. Biggest issue is the steel spring inside the galvanized steel tube and it stays damp. Lots of rust. No way to get any lubricant into it. But if you use it a lot it wears the rust out of the way, I guess.
We bought another trailer with 2 broken springs on the little awnings. Lots of rust inside on the broken springs. My advise is to spray and pray and keep on rolling it up. It will get better. If you can get to a rally with Zip Dee in attendence they can be very helpful.
Old 07-02-2011, 07:36 AM   #10
idmtman's Avatar
Worley , Idaho
Lubricate it first with silicone and if it still needs a little more rolling power, follow the Zip Dee directions. It isn't difficult if you follow the directions and use a ladder to hold the bar. I found our awning needed more turns than the 1 turn per foot.
Idmtman
2006 Safari 28' SE (Sylvia)
75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
idmtman is offline   Reply With Quote
Zip Dee using Silicone?????? SailAS Awnings 19 06-12-2011 12:39 PM
Zip Dee Ultimat crispyboy Off Topic Forum 2 05-19-2011 12:09 PM
1970s era Zip Dee (Curved) Awning funkill Awnings 7 04-06-2011 11:16 AM
Zip Dee Z-lock lever is stuck aname4me Awnings 4 03-17-2011 06:13 AM
Spring Break, TRIP,.. Need help Again. THEPILL On The Road... 18 02-06-2011 11:14 AM
