Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 04-30-2008, 10:04 AM   #1
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Exclamation Need help quick - awning retrofit!
Sorry- but I don't usually need such a quick answer...this time I do!!
will a Zip Dee from a 2003 Airstream 31 footer fit my 1980 31 footer excella? I would think it would but wonder if the curved arms are very different.
I have a chance to get an awning where I don't have one, and it wil almost match my other small ones.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
ALANSD is online now   Reply With Quote
Old 04-30-2008, 10:25 AM   #2
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Originally Posted by ALANSD
...will a Zip Dee from a 2003 Airstream 31 footer fit my 1980 31 footer excella? I would think it would but wonder if the curved arms are very different.
Call Zip Dee. They are very cordial and helpful. Someone there may recall the specs.
The drawings in this post may be helpful. They look pretty accurate to what I see looking at my mid-70's Zip Dees. I think if the 3 bends look similar, you'll be OK.
I ordered a new Zip Dee from Lewster for my Overlander (not installed yet) and he never mentioned any problem with fitting the new stuff to the 70s Airstreams.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 04-30-2008, 10:30 AM   #3
ALANSD
Thanks. I called the mother ship they are trying to help, seems like this might
work!
My Music Site:
Old 04-30-2008, 11:27 AM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
Alan, I found an awning arm to replace a damaged one on our 31', and it didn't fit. The wide body coaches have different arches and attachment areas. The awning itself and roller should fit, but the arms will be slightly different.
Change is inevitable, except from a vending machine
AIR#2611
Old 04-30-2008, 12:07 PM   #5
jimmini
jimmini's Avatar
Profile:  1989 29' Land Yacht
Mesa , Arizona
Zip Dee
Zip Dee Customer service manager Linda Johnson 800-338-2378 or 847-437-0980.She is always a big help. ljohnson@zipdeeinc.com
Jimmini
THE FEW,THE PROUD,THE SQUARESTREAMER'S
ROLLING WITH THE FLOW
WBCCI 8991
CHARTER MEMBER 4CU
jimmini is online now   Reply With Quote
Old 04-30-2008, 12:10 PM   #6
ALANSD
I had two conversations one with Airstream and one with ZipDee. I have to say both were helpful. Linda at zip dee really knows her Airstreams.
Here is the straight scoop from this-
1969 to 1993 Airstreams use the same zipdee measurements and hardware will fit interchangeably. You take the trailer length and subtract 10' 3/4" and that is the patio awning size. It lines right up to the rivet line at this point. For example on my 31 you need a 20' 11 1/4" awning.
1994 and later are different and require a 21'7" awning on the 31 for example.
The metal on the older models is "bright" while the newer are satin.
The curve and the rivet lines differ after 94.
Sooooo- if you have a 1994 or later 31 and need a used Zip Dee, PM me for the info ...it's available( not from me) and is about 1000. Half the cost of a new one.
And if you know of an older used one for mine, fill me in! Meanwhile I will be saving my spare $$ to get a new one. I was pretty excited about finding this one, but the quest goes on.
My Music Site:
Old 04-30-2008, 12:49 PM   #7
Zeppelinium
1977 23' Safari
1975 31' Sovereign
...Sooooo- if you have a 1994 or later 31 and need a used Zip Dee, PM me for the info ...it's available( not from me) and is about 1000. Half the cost of a new one.
Alan, if the freight wasn't so high, I'd ship you the one off my 75 Sovereign. All parts are functional. I took it off to get the sand out of the outriggers--couldn't move them until I got them clean. In the process the awning came out of the awning rail--problem is on my Sovereign, not the Zip Dee. Evidently the PO had a problem and put an extra awning rail on the metal Zip Dee cover.
I'm going with a vintage style awning when I replace it.
Zep
Old 04-30-2008, 06:54 PM   #8
overlander63
Images: 58
Zep
I have a suggestion...such as it is...
Why not box up all the hardware, remove the fabric from the roller, and send everything BUT the roller to Alan? He could then have a roller sent to him, for less than a new awning would cost. It gets the awning to the person that needs it, and Alan gets a cheap awning, some assembly required. He would have to put it together anyway, even if it were brand new.
As someone that replaced the material last weekend, it isn't tough.
AIR#2611
Old 04-30-2008, 08:18 PM   #9
Zeppelinium
1977 23' Safari
1975 31' Sovereign
Originally Posted by overlander63
...As someone that replaced the material last weekend, it isn't tough.
I heard rumors that replacing fabric took two astronuats and a small child (for the sacrifice). I'll think about it--remind me when I get back in two weeks. Gone tomorrow!
Zep
Old 04-30-2008, 08:21 PM   #10
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Alan - why don't you just order new arms from Zip Dee and add them to the new (old) roller available to you?
Marc
3Ms75Argosy is online now   Reply With Quote
Old 04-30-2008, 08:21 PM   #11
overlander63
Images: 58
Zep
97 minutes, no sacrificial lambs needed... details in our fulltiming thread. Enjoy your vacation.
AIR#2611
Old 05-01-2008, 05:49 AM   #12
ALANSD
I have been looking at getting a roller, and then buying the hardware. The hardware is about 400 bucks, I haven't yet found a roller that is the right size for us. I looked at an A&E last weekend, but it was too long.
I actually considerd buying an older 30' trailer here that I could buy for parts, but then I remembered... I just got rid of one
Its the 1D 10t errors as the brain ages....
( 1D10T )
My Music Site:
Old 06-17-2008, 02:20 PM   #13
ALANSD
revived thread---- we decided to go with a vintage style awning. So many have these on their older Airstreams, and although ours is larger, we opted for a 16' Sunbrella fabric awning that will have colors very much like our new striping. I will post photos when ready. Its on its way but will be a little while.
My Music Site:
Old 06-17-2008, 05:00 PM   #14
starflyte1
starflyte1's Avatar
Profile:  2007 25' Safari FB SE
Bonita Springs , Florida
I like your choice! An awning is an important accessory to an AS's appearance and yours will look great!
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
'79 Sovereign 31 ft. Retrofit karlgrube Member Introductions 3 04-13-2008 07:15 AM
Zip Dee retrofit 59er Awnings 5 07-18-2007 02:05 PM
Dual AC Retrofit vswingfield Furnaces, Heaters, Fireplaces & Air Conditioning 14 06-26-2007 08:25 PM
Retrofit towing mirrors altamont Tow Vehicles 1 03-28-2007 04:33 PM
retrofit radio 77 R GO C MH Parts Archive 1 03-01-2004 08:43 PM
