Old 08-03-2006, 09:40 AM   #1
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Need Awning Advice, Pronto!...
Greetings Exterior Restoration Gang,
Yellow Freight just called to inform me that my new Zip Dee CFR (cover, fabric, and roller assembly) has arrived. I would sure like to get the old one off and the new one on before I travel to the Rocky Mountain Vintage Airstream Rally in Creede, Colorado next week.
So, who out there has "been there done that?" How do I do it, and how many helpers will I need?
Thanks mucho!
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 08-03-2006, 10:35 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Hey Ken,
Your new CFR should come with a detailed set of instructions. I assume that you will be using your old hardware and arms. If so, the first thing to do is get a helper. Then, unfurl your old awning and remove the spring tension.
To do this, you remove the rear arm from the trailer and disassemble it so that only the short piece attached to the end casting is left. Be sure to always hold it securely or it will helicopter and could be dangerous. You can also support the awning with a ladder underneath it. Have your helper stabilize the awning while you do this.
You then unwind it (counter clockwise) until all of the tension is off the spring. At this point, you can remove all of the arms from the CFR. There should be 1 or 2 screws in the awning rail holding the CFR in place. These should be removed. Now roll up the awning cloth by hand up to the rail and slide the entire thing out of the rail.
You are now ready to insert the new CFR. The rest is just the reverse of the removel process. There should be a flair at one end of the rail to ease the insertion of the new CFR. It also helps if you spray a little lube (I use DuPont Teflon Dry Lube) into the awning rail. You can assemble the front arm to the CFR but only add the short section to the rear as you have to re-wind the new spring. IIRC, it is 7 turns (clockwise) PLUS one turn for each foot of the awning.
When totally assembled (don't forget the retaining screws in the rail) the awning should need just a slight push to start the retraction.
Let me know if you need any other info..........................
Old 08-03-2006, 11:00 AM   #3
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Thanks Lew!...
Great instructions! Can I do it with one helper, or would it be smart to have two helpers?
Ken L
1966 Tradewind 24
Old 08-03-2006, 11:36 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I did mine with one, but since your trailer is longer, I would go for 2 if you can get them. I thought the hardest part was putting the roll segment back in place.
Richard
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Awning Heads Up!!! JaceBeck 1999 Safari 39 04-25-2006 05:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Awning gwrimmer General Motorhome Topics 1 11-07-2002 11:59 AM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
